Old 06-04-2003, 07:44 AM   #1
mrein3
mrein3's Avatar
Audiovox CCS-100 Cruise Control
KEH is installing the Audiovox CCS-100 Cruise Control on his truck like I have on mine. He asked me a couple of questions and I said I'd send a few pictures. Instead of showing just him I thought it best if I post the pictures for everybody.
I don't work for Audiovox or JC Whitney where I purchased it. The system works as advertised.
The first is a not very good shot of a bracket I "borrowed" from another engine I have in the garage.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 06-04-2003, 07:46 AM   #2
mrein3
mrein3's Avatar
The "cruise module" I mounted on that flat spot on the LF inner fender.
'72 Malibu hard top
Center City, MN
Old 06-04-2003, 07:47 AM   #3
mrein3
mrein3's Avatar
I have a later model HEI distributor. I hooked the blue wire to the "tach" pin on the distributor cap.
'72 Malibu hard top
Center City, MN
Old 06-04-2003, 07:48 AM   #4
mrein3
mrein3's Avatar
The final shot is of the connection to the carb. I used one of the many connectors supplied in the kit.
'72 Malibu hard top
Center City, MN
Old 06-04-2003, 08:04 AM   #5
Blue Beard
Blue Beard's Avatar
Looks like a simple clean install.
Any problems with it or variables in the throttle response?
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 06-04-2003, 08:15 AM   #6
mrein3
mrein3's Avatar
If I pull my boat up a real long grade it eventually doesn't keep up. Most hills it does keep up.
'72 Malibu hard top
Center City, MN
Old 06-04-2003, 01:44 PM   #7
KEH
Better late than never
KEH's Avatar
mrein3,
Thanks for the pics. Does the kit not come with a mounting bracket? Or did the one you put on just work better?
1970 C/10 SWB Stepside
KEH is offline   Reply With Quote
Old 06-04-2003, 05:30 PM   #8
da-burb
"Ochre Ogre"
da-burb's Avatar
I installed the same cruise in the 71 Motorhome before my trip to Tennessee. I loved it. I had to set it to the heavy vehicle setting on the control servo. It didn't slow down on most hills/mountains. It took about 2 hours to install.
After I installed it I figured there are ways to possibly install without having to see the servo. First idea is to install it under the dash near the glovebox and have it pull on the gas pedal. The second idea was to put it between the inner fender and outer fender near the drivers hinge. You wouldn't be able to see much there either. For a show truck I would look at those locations. It would really clean things up.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 06-05-2003, 08:29 AM   #9
mrein3
mrein3's Avatar
I honestly don't remember if I got a bracket in the kit or not. Around the same time I was converting to an auto transmission. I know the bracket on the back of the intake for the kick-down cable came off another engine.
da-burb, was there a bracket in your kit?
'72 Malibu hard top
Center City, MN
Old 06-05-2003, 08:40 AM   #10
da-burb
"Ochre Ogre"
da-burb's Avatar
yes, the bracket came attached to the servo. there wasn't anything to assemble. On my truck, the 71-72 trucks with the accelerator cable, not the rod, there is a hole in the bracket on the carb. I used that to attach the control cable. It couldn't have been easier.
