Old 11-27-2012, 01:32 AM   #1
Skunksmash
Skunksmash's Avatar
Seafoam in brake booster hose?
Is the brake booster hose really the best place to pour in the seafoam? Wasn't sure if that would guarantee even distribution of the chemical. Maybe I'm thinking about it wrong. I'm thinking the the throttle body (TBI 5.7L) would be better. You know, pour it a little at each time down each side? Thoughts?
Skunksmash is offline   Reply With Quote
Old 11-27-2012, 01:40 AM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Seafoam in brake booster hose?
Look for uccc from mopar upper cylinder chamber cleaner.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 11-27-2012, 08:13 AM   #3
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Yea, if you plan to change the spark plugs afterwards. Otherwise, pour it in a full tank of gas. Using the vacuum hose or TB is the extreme version if you need to try can clean carbon deposits.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 11-27-2012, 09:04 AM   #4
bk2life
im totally confuzed..
bk2life is offline   Reply With Quote
Old 11-27-2012, 09:19 AM   #5
gchemist
gchemist's Avatar
If your truck is FI, pour it in a full tank of gas. Use TB cleaner to clean the upper parts.
What is your primary reason for using it?
Old 11-27-2012, 04:57 PM   #6
Skunksmash
Skunksmash's Avatar
Better than seafoam, I assume?
Just to clean things up and help it run better. I've heard of people having great results with it. Improved mileage, some restored engine performance, smoother running engine, etc. Lots of people seem to think its helped them.
So the putting it in the gas tank is just as good as pouring it in the brake booster hose? On the bottle it says to do both. I guess I can see how it ends up in the same place. But then why would they tell you to use that method. Some people even put it in the oil and drive a few miles then change the oil.
Old 11-27-2012, 05:29 PM   #7
bnoon
Seafoam is good to use at all of those places. In the tank cleans mostly the fuel system with a very minor clean to the combustion chambers. Into a vacuum hose is much more direct on the combustion chambers and is good if you've got a lot of soot buildup. Into the crankcase will clean a lot of the sludge buildup from the crankcase, lifter valleys, heads, etc. It all depends on where you're trying to clean.
- 1981 Sierra 454, NV4500 swap
- 2006 Z06, 25k miles
- 1973 Nova - Project CarNova Virus on Youtube
bnoon is offline   Reply With Quote
Old 11-27-2012, 06:45 PM   #8
Skunksmash
Skunksmash's Avatar
Been reading and others don't seem to think it will foul the spark plugs. Just that some people who did it wrong have done that.
Old 11-27-2012, 07:54 PM   #9
JCampbell
I've used it. In both occasions I poured it *S-L-O-W-L-Y* into the throttle body.
Worked fine...I guess. Noticed a little bit of a difference. The smoke show was fun. Reminded me of Uncle Buck.
JCampbell is offline   Reply With Quote
Old 11-27-2012, 08:08 PM   #10
bnoon
Yeah it smokes like a mofo for quite a while!
Old 11-28-2012, 03:38 AM   #11
zaccaglin
zaccaglin's Avatar
Love Seafoam. Poor a can into a 1/4 of a tank every month. Run it for a few days then fill up the tank. Seems to run better within the week.
Zaccaglin
1998 Chevrolet C1500 Ext. Cab 350
Former Rig:
1985 Chevrolet K20 Suburban 6.2L Detroit/TH400/NP208
zaccaglin is offline   Reply With Quote
Old 11-28-2012, 04:55 AM   #12
INSIDIOUS '86
Originally Posted by Skunksmash View Post
Better than seafoam i assume? l.
Yes because sea foam can only clean what it touches. The mopar stuff foams up when the engine shuts off and fills the cylinders with foam and the intake so it cleans stick carbon throughout the cyl chamber and the top of the intake runners where carbon commonly sticks.
Also look do a/c delco carburator conditioner. It's spray seafoam and great at keeping your carb venturis and engine clean
http://www.autopartsasap.com/Mopar-0...r-Cleaner.html
http://www.acdelco.com/parts/vehicle...p-conditioner/
Old 11-28-2012, 09:13 AM   #13
gchemist
gchemist's Avatar
Don't inhale the SMOKE!!
Old 11-28-2012, 04:58 PM   #14
JCampbell
Old 11-28-2012, 05:05 PM   #15
1978chevybigten
1978chevybigten's Avatar
Originally Posted by JCampbell View Post
Lmao!
1978 big ten 350/350:chevy
1978chevybigten is offline   Reply With Quote
Old 11-28-2012, 11:59 PM   #16
JoeyBones
I'll have to say that the stuff made an incredible difference in my old 91 bmw...I'll definitely be using on the truck when i get the time to do some real maintenance.
JoeyBones is offline   Reply With Quote
Old 11-29-2012, 06:23 PM   #17
Skunksmash
Skunksmash's Avatar
So anyway, would the brake booster hose give you even distribution of the seafoam? Seems like it would kinda benefit the back two cylinders the most. Unless I'm doing it wrong. And by doing it I mean thinking about it.
Old 11-29-2012, 08:40 PM   #18
99-LS1-SS
99-LS1-SS's Avatar
I saw a video today that said you only need to pour it in the booster hose if you have fuel injection. It said for a carb or TBI pour it into the carb or TBI. Just my $.02
My 1972 2WD Blazer build
1984 K10 beater truck
99-LS1-SS is offline   Reply With Quote
Old 11-29-2012, 08:43 PM   #19
INSIDIOUS '86
No it's not going to distribute evenly. The back four are going to sick it up period. Get spray seafoam and spray the throttle body.
Old 11-30-2012, 04:45 AM   #20
Skunksmash
Skunksmash's Avatar
Good point. Will do. Wonder if its the exact same stuff that comes in the can. Probably is.
Old 12-01-2012, 02:17 AM   #21
Skunksmash
Skunksmash's Avatar
Only thing is you have to just sit there and keep spraying it. The can is cooler cause you just dump it in.
