Inner fender to cab mount
Why did this kit come with (4) grommets. I know were two of them go not sure of the other two.
Thanks for the help |
Re: Inner fender to cab mount
I had the same question, I never used the other two..... When I took the truck apart there where only two used.....
People who make excuses didn't want to do it in the first place! ![]() http://s1326.photobucket.com/albums/...cpZZ1QQtppZZ16 |
this one came off a 61 and is org. the grommet is sandwiched and a bushing going through the middle where the bolt goes. so one is used on each side of the inner fender. don't know about other years.
1961 chevy K10 my build is------------61K10 build |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
My 65 was just like above, sandwiched.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
60-66 Nut
![]() ![]() Join Date: Mar 2007
All the ones I remember, were 2 grommets each side, with the tube thru the center. And I believe the correct bolt is a shoulder bolt.
