1990 No Up Hill Power?
I have a 90 350 tbi 5 speed 4x4 that doesn't have any error codes in it.When I go up a hill blue haired old ladies pass me up.It cuts out like its starving for fuel or fouling out atleast 2 plugs.Once I get over the hill it runs much better but still doesn't like anything with some throttle in it before it starts cutting out.
I replaced the entire fuel pump assembly and measured at the filter running it looks like 10 psi. I replaced both injectors and the filter. I removed the catalytic converter and am running a test pipe. Most of the small parts on the exterior have been replaced atleast once. I replaced the computer but not the circuit chip that goes on it. I am starting to think it is electrical. I am the original owner and the motor is a newer crate motor from GM with probably 20,000 miles on it. Any help or ideas are appreciated. Lynn |
| Bookmarks |
