11-27-2012, 01:34 PM | #1 |
Steering Column problems
when putting my truck into Drive or Reverse or Nuetral it is very easy. almost too easy to put into gear. kinda looks like its coming out of gear when in Drive or Reverse. But the problem is when im in gear and wanting to put the truck in Park, it sometimes wont go into Park. so then ill have to put it in Nuetral and try again. Basically its very hard to put truck in Park, any suggestions? ive heard it might be the shifter linkage? or is it inside the column? either way i need help and need answers, thanks.
11-27-2012, 11:21 PM | #2 |
The Older Generation
Re: Steering Column problems
Try reading through my posts in this thread, and see if trying some of my suggestions helps in your situation. http://67-72chevytrucks.com/vboard/s...d.php?t=531124 Oh, and to the board... LockDoc
11-28-2012, 12:40 AM | #3 |
Active Member
Good info LockDoc...
I once had a similar problem on my truck and had to remove the column, take every thing apart and basically chisel old grease out of it. This hot Texas weather had dried up the grease until it made it extremely difficult to shift especially when pulling the lever towards me. I cleaned it all out with diesel and relubed. Doesn't sound like this is the problem here but the posts that LockDoc sent may help isolating it.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
11-29-2012, 03:09 PM | #4 |
ill try taking column apart and putting back together
on that diagram tho what numbers would i spray with pb blaster? like what parts would i have to clean are should i look at |
11-29-2012, 03:17 PM | #5 |
Before dismantling the column try some penetrate in and around the shifter where it goes into the column. Spray and work it a little a few times.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
11-29-2012, 03:24 PM | #6 |
X2 My C20 had a similar problem when I first got it....a little AeroKroil and it loosened right up....just gunked up....
Larry 1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green" 1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red" 1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon" 2005 VW Beetle Diesel 44+ MPG "Silver Bullet" |
11-29-2012, 09:06 PM | #7 |
Is the tip of the shift indicator broken? I had two different columns in two days with the same thing the pointer broke and then the indicator dropped down a bit, causing it to bind up going into park if it would go intop park at all. I know it sounds silly that a little piece of plastic can hold up the whole show like that but it didi I took a little dental hook tool [love them they have 1000's of uses] and dug out the pieces and then it was all freed up once again. That is something to look for that does'nt cost anything and won't cost anything to fix either, so it might be worth a look. Jim
