Original engine?
Hi guys,
Out of curiosity how do I find out if the engine in my truck is the original engine? I have attached 2 pictures. Truck is a 1972 Chevy C20. ![]() ![]()
Thanks, Emil 1972 Chevy C20 |
Amazed Member
![]() Join Date: May 2010
Re: Original engine?
Get the numbers and letters off the block. See the highlighted area in your pic below... You can go to a couple different websites that will help you de-code it.
![]() 1950 3100 Original Project! |
Amazed Member
I'll try again?
Great, thank you!
To pin point it you'll also need the casting number (rear deck drivers side) and the date code (rear deck passengers side just below the distributer.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
Might find some helpful information in a thread I was posting to yesterday.
http://67-72chevytrucks.com/vboard/s...d.php?t=553647
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Thanks for the help guys!
Moderator
![]() Join Date: May 2007
The only way to tell is if you have the protecto plate or build sheet.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Have you ever seen an engine build code written in on a build sheet? All I can remember seeing is the typed RPO and the suffix code like this box 11 example.
