11-27-2012, 08:32 PM | #1 |
what happends if?
what happends if my fuel seding unit has the frame ground disconnected?
right now i changed my gas tank and my truck used to start right up before i changed the fuel tank, now it wont start, i checked and im not getting has in the carb, my old fuel tank had frame ground disconnected too, Posted via Mobile Device |
11-27-2012, 08:55 PM | #2 |
Re: what happends if?
Is your sending unit getting power?
Dan 83 Chevy K10 Scottsdale, ZZ4, TH700r4, 4.10, 33" |
11-27-2012, 08:56 PM | #3 |
i dnt know? is there a way to check?
11-27-2012, 08:57 PM | #4 |
The ground wire for your sending unit only has to do with your fuel gauge, not fuel to the engine. Check to see if you have any kinked fuel lines and that they are connected properly to the fuel sender. If they look good I would use starting fluid to get the engine running and that will help prime the fuel pump. Good luck!
11-27-2012, 08:58 PM | #5 |
With a multimeter. Hatzie posted wiring diagrams at http://67-72chevytrucks.com/vboard/s...d.php?t=545416 and it has helped me a lot
11-27-2012, 08:59 PM | #6 |
i had this happened to me once and i changed the fuel filter and it worked but it has new filter i might havr to check it
11-27-2012, 09:05 PM | #7 |
If it doesn't power the sending unit can you cyphen purl out of the line to your fuel pump?
11-27-2012, 09:24 PM | #8 |
Is your fuel pump in the gas tank or mounted on the engine?
11-27-2012, 09:24 PM | #9 |
on engine
11-27-2012, 09:31 PM | #10 |
Then the engine should run if you have the fuel lines conected properly. Try the starting fluid and see if that primes the engine.
11-27-2012, 09:33 PM | #11 |
earlier i used starting fluid and it turned on for a few seconds then shutt off and i tried to statt it without starting fluid and would start up only turns over like if it had no gas
11-27-2012, 09:46 PM | #12 |
You might try to keep it running with the starting fluid for 5 to 10 seconds. That should be enough time to get the air out of the lines. If that is not it then I would look at your connections again. If your fuel tank sender has two fuel hoses going to it could you have reversed them? One of them is a vent and the other is the supply for the fuel pump. If the nipples are two different sizes the larger one goes to the fuel pump and the smaller one is the vent.
11-27-2012, 09:49 PM | #13 |
maybe thats it, i will have to check tomorrow because i unhooked the fuel line from the fuel pump and no gas came out, it was dry
11-27-2012, 10:29 PM | #14 |
78K & 79C Jimmys
how many lines/sizes
1/4 return 5/16 vent 3/8 main feed 1/2 filler vent my 79 Jimmy you can syphon from the tank any where along it just has to be lower then the tank so a tin can under the front even
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
11-27-2012, 11:04 PM | #15 |
has 2 lines
11-27-2012, 11:08 PM | #16 |
i would say that if you fill the bowls on the carb with gas from a bottle it should prime fine if the lines are right. stop useing strating fluid to get it going a spray bottle is all you need to feed it thro the carb air inlet or like i said fill the bowls. if your lines are backwords i think that the vent is right on top so you will never get any gas from it.
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph 1985 k30 "the ice cream truck from hell" no rust az truck 197-8??? c30 "ramp truck" 454 1978 monte carlo 350 350th with 2.73 gears. no rust. sc car |
11-27-2012, 11:36 PM | #17 |
78K & 79C Jimmys
if i have to put gas down the carb
I use a small plastic soft drink bottle with a screw on plastic cap poke a small hole in the cap,and you can squeeze into the carb safely
11-27-2012, 11:47 PM | #18 |
thanks for the tip
11-28-2012, 09:52 AM | #19 | |
Moderator
You have a carburetor so it has nothing to do with fueling. I'd check that the vent, feed, & return lines are connected to the correct sender lines.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
11-28-2012, 09:55 AM | #20 |
i will check later on today
