Old 11-27-2012, 08:57 PM   #1
mjo8585
mjo8585's Avatar
Flip kit, flip kit, do I need a flip kit???
Hey guys i have a question that I HOPE has a few good answers. So I have a 74' C20 2wd that I lowered last summer. I put drop shackles/hangers and 3'' lower control arms. I still am not happy with how it sits. I looks like a stock 2wd 1/2 ton now. My father has MS and still cannot get into it easliy..thats the reason I lowered it. I want to try drop spindles and a flip kit in the rear but Im worried the stance will be all kittywampas..I cant afford a good air bag setup right now and really hope someone has run into this problem as well. it currently has 16'' wheels now and I want to keep them that size. Can anyone help??
mjo8585 is offline   Reply With Quote
Old 11-27-2012, 09:41 PM   #2
cory d
cory d's Avatar
Re: Flip kit, flip kit, do I need a flip kit???
you could cut one coild for another 2" and then remove some of the shorter leafs. those hold allot of arch and if you have 8 plus the over load then try keeping 4long springs and the bottom one.
cory d is offline   Reply With Quote
Old 11-27-2012, 10:26 PM   #3
INSIDIOUS '86
INSIDIOUS '86's Avatar
Well you may not be happy with the fact that you will have to get rid of the lowering setup you have now to go lower.
Front needs stock arms and some cut stock springs and some drop spindles
The rear can be flipped with a western flip kit but the hangers need to go back to stock. You can keep the rear kit you have currently and change the stance by swapping the rear stock hangers with lowering hangers as well
I would also suggest maybe a swiveling captains chair from an elcamino or van or something. May make things much easier
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 11-27-2012, 10:35 PM   #4
J Knight
J Knight's Avatar
It looks from the pics you could get a decent drop from a set of lower profile tires. You may not have much room to drop the suspension in the front with those tall tires.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 11-29-2012, 03:08 AM   #5
mjo8585
mjo8585's Avatar
thank you for the reply everyone!
Old 11-29-2012, 09:19 AM   #6
Desert1957
Desert1957's Avatar
Yea, I was thinking this also. My 3/4 ton tires were almost 31" tall.
Desert
Desert1957 is offline   Reply With Quote
Old 11-29-2012, 11:40 PM   #7
trout
You could put 1/2 suspention under it and it could drop it a bunch
Edited by staff
trout is offline   Reply With Quote
