Thats the Hillbilly way
Problem Suddenly Dying??
Just when I start redoing the Dining room and Daugthers Bathroom, The truck has been Dying while driving.
It shuts down without notice ,No radio or anything .I wait a couple of seconds or a minute and it will fire back up ,also notice the radio stations are not set .Like I had disconnected the battery ,but it was running when it happened? any suggestions THANKS
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , |
Binder Rep
Bulkhead connector?
![]() Join Date: May 2002
could be the wires that go to the battery not making a good connection
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD ![]() Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
Also dont forget the positive junction on the inner fender just beside the battery.
![]() Join Date: Mar 2000
Check your igniton switch wires. I just went through this and had 3 seriously heat damaged connections. I also found my heater switch wiring and connectors in need of serious attention. I had the exact same symptoms!
Saskatoon, Saskatchewan Canada Last edited by StingRay; 06-04-2003 at 02:06 PM. |
Make sure that the alternator brackets, bolts, wires ect. are all tight.
SKINNY TIRES RULE!
I'd check to make sure it is grounding properly too. Are your cables in good shape?
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
Livin' it up.
![]() Join Date: Nov 2001
Bill i had that happen too. it looked like the wires were connected well but when i checked them better they had shorted. Simple connectors fixed it and make sure that ground is somewhere good. Good luck.
-Greg; Sold the 69 C20. It's off to a better home with more love! Now onto the 86 CUCV M1009; K5 blazer with 6.2L diesel, corp 10 bolt axles, Detroit locker in the rear, trutrac front, 3.73 gears, 35" tires. ![]() |
Thanks for all the quick responces ,
After I get out of my paint suit and finish sanding the plaster walls ,I 'll start checking . Big69C20 Toy what wire did you find shorting? Thanks Bill
I had this happen also. It was my ignition.
I had a vehicle do this and it turned out my ground to the motor was bad. Since my alternator was on the engine and the battery ground was connected to the engine block it would die when ever I hit a bump.
![]() Join Date: Sep 2001
I've seen alternators do this.
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
#13 |
SKINNY TIRES RULE!
Mine was dying a lot & it was the plug into the back of the ignition. Since I don't have a radio, I couldn't tell you if the station presets were gone when it worked again. The plug was heating up while I was driving and then it would loose the connection. When I pulled it, the plug was totally melted.
#14 |
The only thing I found so far was the Alt connection at the Battery was loose so I soldered it .I don't think this would affect the radio though. The battery was 12.4 V and with the truck running the Alt is puting out 14.4 V
I'll try to find another ignition switch , Thanks
#15 |
Check the ig switch plug and each individual contact in it. Mine was like bouncy's and acted up after it heated up. You can insert a small wire or jewelers screwdriver into the contact housing and remove the idividual contacts. Then you can take a dremel with a super fine wire brush and burnish the copper or brass contacts on the plug side and the switch side. You can also tweak the spring tang on the wire contact so it has a better bite. If severe heat has occured then the spring tang will loose it's temper and will no longer make proper contact with the switch contact. These can be repaired by cutting a donor piece from another harness and grafting it in with solder and heat shrink. Remember to bend the retaining tang back up before re-inserting the contact back into the plastic housing. Plastic contact housings can also melt down and require replacing as well.
Saskatoon, Saskatchewan Canada |
#16 |
this just happened to my sons truck, it was dirty battery post, we kept over looking the battery posts, cause from the out side they looked clean. he was driving along and all of a sudden every thing would quit working, cleaned them and it hasn't done it since
#17 |
Well you could---ARGH...BLAU.....
(Cobalt suddenly died). ![]()
