Old 11-27-2012, 11:24 PM   #1
72restorationvirgin
Active Member
72restorationvirgin's Avatar
Exclamation GM posi lube vs. AC Delco????
So I had to order some other small parts and ordered som posi diff lube from Classic Indusries. When I ordered it it stated GM additive and showed the GM bottle. But they gave me a AC Delco bottle which the show as the same part number. Does it really matter or do I need to call and complain???? Is one better than the other?
72restorationvirgin is offline   Reply With Quote
Old 11-28-2012, 12:02 AM   #2
Davemotohead
Davemotohead's Avatar
Re: GM posi lube vs. AC Delco????
Dump it in,,AC Delco is GM,,I Know its forbidden,,But I find the ford Stuff works better!
Davemotohead is offline   Reply With Quote
Old 11-28-2012, 12:08 AM   #3
72restorationvirgin
Active Member
Ha ok thanks..... Ford..... No comment
Old 11-28-2012, 01:02 AM   #4
crazy longhorn
Fabricate till you "puke"
Just say FERD, then its legal on the Gm board crazyl
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 11-28-2012, 05:57 AM   #5
big d's red67
big d's red67's Avatar
Originally Posted by Davemotohead View Post
: I find the ford Stuff works better!
Thats what I use. I used to sale car parts GM and AC Delco same thing just different lable.
1967 swb 454 cid 700R4 trans SOLD
2006 Chevy Trailblazer SS
2013 Camaro RS convertible the wife's
Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=573248
big d's red67 is offline   Reply With Quote
