Old 11-28-2012, 12:25 AM   #1
morgan357
changing?
Hey, I am new to this site so lets see if I can figure out how to ask this without sounding like a moron. I have a 66' c10,lb step, big window, 292, and 4 on floor. I have decided to "build" a chassis swap for lack of better words. I am looking to find out if there's a year or years of truck someone can tell me i can buy that has the following; disc front,pwr steer, pwr brakes, 2 wheel drive, 5 lug front and rear. I want to stay with my ole' inline 6. I know it's crazy but I don't hot rod, I cruise. I am also after a million plus miles under my belt a LAZY driver. I WANT AN AUTO TRANS!!! that'll match to my 6? Trucks in this part of the country are easy to come by pretty cheap so help out a fellow Chevy lover? Thanks
morgan357 is offline   Reply With Quote
Old 11-28-2012, 12:32 AM   #2
ol_skool_chevy
ol_skool_chevy's Avatar
Re: changing?
just get a 66' frame and a 1972 or later donor 1/2 truck and move it all over into the 66' frame.....easy as pie.
its all the same...only real differance it per i beleave 1968 had all drum brakes.
its all a bolt up change over,
and depending on your rear gears with a 292...if your a 3.50 gear or lower i would use a 700r4,
thats my .02 worth....im sure others have other ideas...all good..
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 11-28-2012, 12:36 AM   #3
shortbed70
shortbed70's Avatar
Re: changing?
Welcome first off. Secondly ill try to answer some questions for ya. For disc brakes you can get a complete crossmember from a 71-87 will work with minor issues. 71-72 are most common swaps. Get everything steering box, linkage etc. secondly you have a few options on the rear, you can swap for a 71-72 rear (they are 1-1 1/2" wider) than yours now or get with a vendor on site or early classics,cpp etc to get 5 lug axles.. But remember you need drums or disc for the rear I you buy axles and look at captainfab on here for steering box adaptor plates! Top notch... Get a duel pot master also from above options also. As far as trans you can go 350,400 or overdrive 700r4 or 2004r and will probably need a trans crossmember for any option. Good luck on your truck and search some build threads for more info
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
