Old 11-28-2012, 04:19 PM   #1
GMC Guy
GMC Guy's Avatar
Limiting pressure to rear discs
I'm going to be doing a rear disc swap pretty soon and would like to know what is the best way of limiting line pressure to the rear brakes. if anyone has a part number or knows a cheap way to make the whole system function correctly, that would be much appreciated!
Greg
1974 GMC
1/2 Ton SWB Fleetside
L33 5.3/4l65e
.................__
............._____l __\__
..............l_(O)_ l___(O)]
GMC Guy is offline   Reply With Quote
Old 11-28-2012, 04:24 PM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Limiting pressure to rear discs
A brake proportioning valve is likely all you need
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 11-28-2012, 05:26 PM   #3
Keith Seymore
Keith Seymore's Avatar
Aftermarket adjustable prop valves are available through places like Summit, Jegs or other brake specific catalogs.
You can fine tune the brake feel you like with the twist of a knob.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 11-28-2012, 05:38 PM   #4
GMC Guy
GMC Guy's Avatar
http://www.summitracing.com/parts/rsd-pv72/overview/
this one?
or this one?
http://www.summitracing.com/parts/sum-g3905/overview/
Greg
1974 GMC
L33 5.3/4l65e
.................__
Old 11-28-2012, 10:07 PM   #5
Keith Seymore
Maybe (non adjustable, depends on the pressure slope they've built into the valve)
and
Yes (adjustable)
K
1979-1986
1986 - 2019
Old 11-28-2012, 11:10 PM   #6
GMC Guy
GMC Guy's Avatar
where is the optimal place to install it? near the master cylinder or just wherever is convenient?
Greg
1974 GMC
L33 5.3/4l65e
.................__
Old 11-28-2012, 11:42 PM   #7
INSIDIOUS '86
Any where. I would go by the master cyl so it's out of the way
