Brake lights stopped working
64' c-10 brake lights and license plate lights working one minute and not the next then presto they are back on again - Where should I start looking to tracking this problem down??
Re: Brake lights stopped working
One of the first place that I think of make sure you have a good clean conection for ground..
Bob |
brake switch or turn signal switch.
Check the harness connections at the firewall , rear harness 1st. Sounds like you have power and then loose it. Also check the fuse....had one go bad a while back...would touch and then break circuit when turned left or right.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
![]() Join Date: Aug 2011
Sounds like a loose wire or connection. Might be a switch under the brake pedal going bad also. And check that it is grounded well.
http://s994.photobucket.com/albums/af62/ScottAz2/ |
I soldered a ground wire to every light housing on my truck, then grounded them all to the frame via a grounding block. All the difference in the world.....lights are all very bright. Kieth
#7 | |
![]() Quote:
BTW: Taillights and license plate lights are on the same fuse with dash lights. That way, anytime one had a fuse blow that caused his taillights to go out(a dangerous situation), his dash lights also went out(not dangerous, but aggravating AND eye-catching) to warn him to fix his taillights. Brake lights are NOT on that fuse--another fuse AND another circuit! ![]() sam |
