Anyone swap their trailing arms?
My trailing arms are looking pretty old and "beat up" looking. Was thinking about taking them off to be powdercoated and put in new bushings and then I seen these on ECE website. Look pretty nice. Say they are heavy duty and come with all the bushings.
Thoughts? or anyone has done this? Would love a pic of them on a truck. Thanks. Weev-
Weev- Life's tough...... It's even tougher when your stupid - John Wayne |
Re: Anyone swap their trailing arms?
Pretty expensive option. They look good tho. What's better about those than stock?
Posted via Mobile Device |
![]() Join Date: Oct 2012
I just installed those arms on my '71 a couple weeks ago. They are nice. They are heavy rectangular tubing,all 1 piece and are capped on both ends so no moisture can get inside them. They also came with U-bolts,spring retainers and grade 8 hardware and have poly bushings installed in them. Overall, I was very impressed with them. They are great quality and came powder coated and ready to bolt in. I can take a pic of mine installed tomorrow. The bed is off the truck so you can see them well.
Watch out for your cornhole !
![]() Join Date: Jun 2003
That's a lot of scratch to spend if your current arms are solid. A set of poly bushings and powdercoat will be about 250 dollars cheaper than buying the ECE ones. That's 250 dollars you could use to buy other stuff.
#5 | |
I recently pulled my trailing arms off (during rear spring install) because they were rusting pretty bad on the rear ends and splitting. Bought another set off a board member here for 120 shipped and plan to spot weld the seams to reinforce them and then clean/paint them up and theyll be good as new. ![]() On the other hand, depends what you are trying to build. I am just building a driver quality weekend cruiser. If you are wanting a show quality, fully restored, top notch rebuild and best of the best... it might be worth buying those from ECE if your other components are going to be similarly beefed up. Up to you!
1970 Chevy C-10 Stepside My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=528167 ![]() |
![]() Join Date: May 2010
If you decide to stay with originals, try forum member t korinek. He usually has some and is in Mesa, so you could save shipping.
im building these right now!
3 inch drop ![]() |
I would rebuild the OEM ones no doubt about it
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
#9 | |
Weev- Posted via Mobile Device
Old member
If I ever get the extra cash I'll be buying a set of these. I installed the "No Limit" shock relocator kit on mine and these will work with it. Porter builts want. There's have no provision's for the shock kit, and yes I called and talked to them about it. They wouldn't make me a set.
A factory set in good condition is OK but they need to be biffed up some. I don't have the welder to do it, so these will be a added bonus to the truck when and if I ever get them. ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
I have had the ones from ECE for about 4 years now and they are excellent and money well spent.
they are solid, no flex and look great .. If you have the money I say go for it...
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
Stock Car Products sells a nice set of original style arms for about 300$. I was always told that the originals were designed to have flex in them and if not the front mounts would eventually fail. However if you've run these for 4 years that puts doubt to that. Is your truck a daily driver?
#13 |
#14 | |
![]() Quote:
big al- Hows the ride w/these arms? My truck isn't drivable yet. I just wondered if you could tell the difference over stock. I looked into repro. stock arms and ECE's arms were actually only a few dollars more and came with u-bolts and poly bushings and hardware. I was also impressed w/ the design and strength improvement. Last edited by starfire58; 11-29-2012 at 11:27 PM. Reason: add |
#15 | ||
My truck is not a daily driver, it is a weekend cruiser that gets driven hard with a built 406. there is zero flex and in combination with the front muscle sway bar from ride tech this truck drives like it is on rails with zero bouncing nor body roll. I am giving you opinions of these arms on two different set ups I have had thus far first three years it was on a static drop and now it has been bagged for one year and of course bagged is even better.
#16 |
Thanks for the info. I've yet to start on the rear suspension. Thought about building my own and hanging coil overs behind the axle with a full length track bar. We ran truck arms on our late model stock car and that thing would really squat and hook up coming out of the corners. There is so much different info out there, it's nice to hear real world. I'm running a built 402 big block and I plan to bang on it. Any thoughts on the coil over idea?
#17 |
Great product
Scott 67 c10 sold 89 c1500 90 k2500 91 s10 #chevyonly ![]() |
#18 | |
#19 | |
Old member
![]() Quote:
Nascar uses a simlar setup to this and I have never herd them state they want them to flex. big_al_71, as always your truck is just NICE! ![]() ![]()
#20 |
they run the Same trailing arm as our trucks on NASCARS,,,,,if they can run 200 plus miles an hour....i think they are fine..no need to make better
Measure with a yard stick Mark with Chalk Cut with a torch ![]() Built it yourself, don't count on others to to do it for you or with you. It will never get done |
#21 | |
Old member
![]() Quote:
#22 |
Stocks arms are plenty good. Have you seen Stacy davids 67 c10 copperhead build?? He put a 572bb in it with stock arms. I would image you would get flex given the I-beam design but they do also make flat plate to box then in to "stiffin" them up. So the day you turn your drive line into a candy cane I'd then worry about beefing up your trailing arms
#23 |
![]() Join Date: Oct 2009
I think the deciding factor here is horsepower. If truck is a daily driver, stick with stock. If truck has lots of ponies and sticky tires, the stock ones can come apart since they are just two pieces of thin metal tacked together. Guess it is like the old saying, if you want to play, you gotta pay. Lol.
#24 | |
#25 |
I bought a set from Classic Parts. Fully boxed square tubing, $50 more than a new stock type set. I like em.
=MATTHEW 69 Stepper...Stroked & Bagged ![]() 2003 Chevrolet Z71 Ext. Cab 1995 Cavalier gas saver! |
