11-29-2012, 12:03 AM | #1 |
Rear Frame Mount for 71 Blazer
So I am slowly upgrading the Beast, and one of the next steps is replacing the old worn body bushings with new ones. I'm leaning towards the Ploy-graphite ones from Prothane.
So looking over the Blazer I found that the Rear Frame mount by the rear bumper is completely rusted out. I went looking for a replacement mount or If I couldn't find one fab one up. I found this on the Brother's website Link: http://http://www.brotherstrucks.com...number=FM72CMR I can't tell if this is the right mount for that location any thoughts
Gary 1971 K5 Blazer 350 V8 |
11-29-2012, 01:37 AM | #2 |
Collector of Projects
Re: Rear Frame Mount for 71 Blazer
The very last mounts are boxed sheet metal that are welded to the floor....
The second to last mounts are rivited to the top of the frame.... |
11-29-2012, 01:45 AM | #3 | |
I was looking at this picture in the service manual and it looks like the Brother's part... But from what you are saying it appears as if this part is not correct
11-29-2012, 02:38 AM | #4 | |
Justin |
11-29-2012, 12:54 PM | #5 | |
11-29-2012, 01:37 PM | #6 |
Hello GFREEZE1025!! I`m from Chantilly, VA so I though I would say HI!!
I just did all my body mounts and most of the job was good, however the bolts on the driver & pass side floor Good Luck!! Nick
68 C10 SWB W/ 72 FRONT CLIP 343SB TH400 64 C10 SWB 406SB TH400 74 SUBURBAN 454BB TH400 78 K10 SWB 350 TH350 6" ON 35" BFG MUD 71 K5 350 W/ TBI 700R4 6" ON 38" BFG MUD 00 K3500 DRW BIG BLOCK "DRINKING PRBLM" |
11-29-2012, 01:55 PM | #7 | |
If the frame mounts, where did you get them? I'd rather buy one then fab something up, but it is looking like I just may have to.
11-29-2012, 02:21 PM | #8 |
To be honest, I did not replace any frame mounts, however I probably should have replaced the rear sheet metal/frames. They are very rusted!!
I just treated the rust and painted them so it would not spread any more.
11-29-2012, 05:34 PM | #9 |
Anyone have a clue where I can find this part? (New or used)...
11-29-2012, 07:21 PM | #10 |
Someone on had them for sale recently on the parts board. Can't recall who right now, sorry
11-29-2012, 10:12 PM | #11 | |
Thanks again.
11-30-2012, 08:09 AM | #12 |
Yep, that was them. Glad you got them.
12-13-2012, 01:03 AM | #13 | |
What I really needed was mounting bracket/plate for postion #5. The following pics are what I am dealing with.... Passenger side mount looking towards the drivers side Same mount but from the back side (Ie taken from drivers side and looking towards the passenger side. Drivers side is not much better. I am hoping that this is a simple cut and fab job and nothing more... But I am confused as to how the body bolt is stabilized. It looks like a simple box but there is no support for the bolt. It can move and back and forth like this... Anyone with good pictures or description for this fix would be greatly appreciated. On a good note, the guy I bought the car from said he put in a 327 V8. After taking it in for quick tune up, I found out that I have a 350 or at least that is what the casting numbers tell me.
12-13-2012, 01:17 AM | #14 |
The mount is built from sheet metal. In the center of the mount is a tube that the bolt runs through the center to prevent it from crushing. I don't believe they are being reproduced. You could check with one the the vendors who sell new reproduction parts... They would know if its available.
12-13-2012, 12:28 PM | #15 |
Just a nother gear head
only way to get them is to buy the tail pan section for a truck and either cut them off or replace the the whole thing. or you could do like i plan too and make your own from some 2x4 box and a metal bushing.
2013 HD FLHX 2000 chevy 2500 6.0l 4x4 3dr 2000 harley fxdx 71 Jimmy 4x4- future crawler/ woods rig 71 blazer (C4 2wd conv project) http://67-72chevytrucks.com/vboard/s...d.php?t=523589 |
12-13-2012, 11:12 PM | #16 | |
If you are going to make some of those boxes do you mind making two more. I'd compensate you for your labor of course.
12-14-2012, 10:10 AM | #17 | |
12-14-2012, 12:06 PM | #18 |
Great starter project... If you hire someone to do all the resto work... you might as well shop for a finished ride and save yourself a bundle. Don't look at it as one big project, think of it as a buch of little projects. Jump in and do what you can and you'll be hell'a more proud of what you brought to the picnic....
1) Measure the old piece and make a template. 2) Cut the new piece out of some 18 gauge metal (tin snips will do the trick). 3) Fold it with a fancy sheet metal brake and a hammer (see below). 4) Follow steps 2 and 3 once more and then take a minute to admire your work. 5) Tack your new pieces in place and move on to the next project...!!!
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod Last edited by 71RestoRod; 12-14-2012 at 12:12 PM. |
12-14-2012, 12:13 PM | #19 |
nice work 71 restorod. great idea. that looks easy than the way i was planning too.
12-15-2012, 02:07 AM | #20 | |
My only questions is what did you use inside of the box to secure the bolt? A long metal bushing? Or did you just cut a hole in the bottom of the box and call it a day? I am just hoping my box is still intact enough to get some decent measurements. Thanks for the pics
12-15-2012, 02:39 AM | #21 | |
I was able to reuse the tubular pieces on mine. From the looks of your pictures you'll have to get creative with a replacement. A metal bushing would be great if you could find one long enough or you could hit up your local steel supply for a suitable diameter DOM steel tube. Just make sure the ID of your washer is smaller than the OD of the tube!
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod |
12-15-2012, 02:49 AM | #22 | |
Should be a fun project. I'll keep you posted
04-12-2013, 10:48 PM | #23 |
Finally did my body mounts.
Some of the old crap that came out The new ones are in
