Old 11-29-2012, 12:52 AM   #1
ortegamotor
ortegamotor's Avatar
AutoMeter Phantom Gauge cluster
Autometer Phantom Gauge cluster pre-wired and ready to install. put together but never used. there is over $619.00 in guages alone. thats Summit's price. Installed on a bezel all wires are labeled and ready for an easy install.all the guess work is taken out.
$550. plus shipping....
2-5/8"
5885 clock
5891 volts
5837 h2o temp with sender
5821 oil
5814 fuel
5"
5898 Tach
5896 speedo 200 mph
ORTEGAMOTOR
ortegamotor is offline   Reply With Quote
Old 11-29-2012, 12:54 AM   #2
ortegamotor
Re: AutoMeter Phantom Gauge cluster
more pictures....
ORTEGAMOTOR
Old 11-29-2012, 07:13 AM   #3
olskoolchevy
olskoolchevy's Avatar
Very nice set up. Where did you get the clock and adapter to make it fit in the 3 3/8(i think) center hole?
Instructions: Just another man's opinion
olskoolchevy is offline   Reply With Quote
Old 11-29-2012, 11:45 AM   #4
ortegamotor
That is a Phantom series clock. I cut out a sheet metal circle out and fit it into the opening. that took the most time. so as you may know the opening on the bezel is tapered so as you tighten the clock from the back side it pulls the sheet metal retainer into the opening and tightens it right up.
ORTEGAMOTOR
Old 11-29-2012, 01:27 PM   #5
ortegamotor
Correction: The gauges are still availible.
ORTEGAMOTOR
Old 11-29-2012, 06:36 PM   #6
vidman
vidman's Avatar
Is this a factory bezel and is there any cracks. interested
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline   Reply With Quote
Old 11-29-2012, 08:30 PM   #7
ortegamotor
It is a factory bezel and there are no cracks.
ORTEGAMOTOR
Old 11-30-2012, 12:33 PM   #8
ortegamotor
ttt
ORTEGAMOTOR
Old 11-30-2012, 06:22 PM   #9
vidman
vidman's Avatar
Would you do 500.00 on the cluster..
Old 11-30-2012, 06:50 PM   #10
ortegamotor
It's yours.... I'll pm you my info. thanks
ORTEGAMOTOR
Old 11-30-2012, 07:07 PM   #11
vidman
vidman's Avatar
Paypal sent...Will PM you my shipping info..Thank you
Old 11-30-2012, 07:29 PM   #12
ortegamotor
you got it buddy. it's on its way. Tony
ORTEGAMOTOR
Old 12-15-2012, 06:42 PM   #13
vidman
vidman's Avatar
Received the gauge cluster today..All I can say is. Sweet
