Old 11-29-2012, 09:54 AM   #1
melhilburn
melhilburn's Avatar
rochestor 1bbl idle needle valve setting
Can anyone tell me the starting point for adjustments of the idle needle valve on my Rochestor 1bbl - 292 in line 6 engine
melhilburn is offline   Reply With Quote
Old 11-29-2012, 10:22 AM   #2
oem4me
Re: rochestor 1bbl idle needle valve setting
I've always started at 1-1/2 turns out from seated on all carbs. Not sure what the manual suggests for your 292.
Old 11-29-2012, 01:04 PM   #3
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Don't forget the vacuum gauge after it's running. If you are running an original distributor you'll be adjusting it at the same time as the mixture screw.
Old 11-29-2012, 03:18 PM   #4
oem4me
Just to clarify, I assumed you were asking about the mixture screw. From memory, adjust the idle speed screw to between 500 and 600 rpm and then adjust mixture needle in or out as needed starting at 1-1/2 turns from gently seated. The vacuum gauge will tell when you have hit peak steady vacuum as you adjust.
Old 11-29-2012, 03:31 PM   #5
BMERDOC
BMERDOC's Avatar
I agree with 1-1/2 turns as a starting point. Don't forget that the idle will raise as you hit the sweet spot and you'll have to adjust the idle along with the mixture as you close in on the optimum setting.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
