11-29-2012, 11:11 AM | #1 |
Doc, what do these symptoms mean?
1 - When I shut my truck off it wants to continue to run. It will sputter fo a times and it wil finnally shut off (reving kind of high).
2 – In the mornings I pump the gas once, truck starts and revs good for about five seconds and then it dies (I can keep it running if I kind of pump the gas once it starts to die). Once it dies, I have to pump gas one more time and then start it and it will stay running, not real smooth but eventually it someths out and revs go up. 3 – I feel like it is taking way too long to warm up and for the RPMs to come down. RPMs don’t come down on their own, I have to ckick it to make them come down, even after I drive it on my ten mile comute to work the revs are still high so if I don’t want the truck to sputter after I shut it off I leave it in Drive and shut it off. 4 – Lastly, white smoke smelling like fuel fumes comes out when I first start it when thruck is cold. Patient is 85, 1/2T, 305, Q-Jet. thanks for the help. |
11-29-2012, 11:23 AM | #2 |
Re: Doc, what do these symptoms mean?
try turning the idea down some and that should stop the run on
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph 1985 k30 "the ice cream truck from hell" no rust az truck 197-8??? c30 "ramp truck" 454 1978 monte carlo 350 350th with 2.73 gears. no rust. sc car |
11-29-2012, 11:24 AM | #3 |
Sounds like a timing issue or a carb tuning issue....Mine is doing similar since I replaced my carb
Could possibly be the cold weather but im just making educated guesses from what Ive heard/read....
PLEASE HELP WITH PROJECT UNDERHAULIN http://67-72chevytrucks.com/vboard/showthread.php?t=306320 Gemini - 1978 GMC C15 High Sierra - 305 c/e - Given to Mother Electra - 1967 Mustang Coupe - 302/w 3 speed Build Chyna - 1968 Chevy C20 Long Stepper
11-29-2012, 11:51 AM | #4 |
86c20 was trying to say idle not idea. The "run on" term is called "dieseling". (not trying to correct you 86c20, just clarifying for our friend here) Your idle is too high. Your choke is probably out of adjustment. If the carb has been on your truck for a while and just started these symptoms it may be time for rebuilding or replacement.
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
11-29-2012, 12:12 PM | #5 |
bmerdoc its all good. if some one gets me its a good day lol. but yea that is what i was trying to say.
11-29-2012, 12:53 PM | #6 |
so the idle being to high is taking an effect on all of my symptoms or are we targetting one specific. also you mean the idle on the choke side correct or the idle screw once its hot, see i dont know the proper terms either so hope you know what i mean.
as far as the carb, i had it "rebuilt last march, by a mechanich that said "Q Jets are my experties" but it has not been performing at its peek even fater the so called rebuild. we went back and forth on settting it right but not he just couldn't getting, "excuses/try it and see how it does" we i got tired and stop going back. thanks. |
11-29-2012, 02:40 PM | #7 | |
78K & 79C Jimmys
3.revs or choke won't turn off till you hit the gas and knock it off,stuck on will smell gassy,and diesel
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
11-29-2012, 03:04 PM | #8 |
Being that it was "rebuilt" you may have to start over and check all the settings on the carb. Because it is a Quadrajet you'll wanna check the throttle shafts first by wiggling the shaft to check for excessive play. If you are getting air seepage through the throttle plate past the throttle shaft you adjustments won't matter.
11-29-2012, 03:06 PM | #9 |
been there with a holly
11-29-2012, 03:24 PM | #10 |
http://67-72chevytrucks.com/vboard/s...d.php?t=553926
This quadrajet thread is currently active and has some good info.
12-01-2012, 02:11 PM | #11 |
Another Day, Another Dollar
Sounds like my truck
Check to see if your throttle linkage is sticking I know mine does when it's cold. I actually use the 'high idle' to my advantage to warm the truck up and prevent it from stalling when cold. I know I'm up to operating temp when the throttle stops sticking. Also shut your truck down in gear and it won't diesel anymore. If you let it diesel you could potentially bend a valve Posted via Mobile Device
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box "its hip to be square" |
12-01-2012, 02:15 PM | #12 |
Obviously a band-aid fix but you do what you do when you can
12-02-2012, 02:55 AM | #13 |
In my experince with rochester carbs.If your engine continues to run after you shut the key off your float is no good.Its sinking and allowing the fuel bowl to over fill.When your air cleaner is off the carb and you shut the engine off is there vapor coming out of the carb ?If so then it's your float.
12-02-2012, 08:10 AM | #14 |
Easy first step - remove air cleaner and check to see if the choke valve is fully open when the engine is running. IF not fully open, pull the throttle back all the way with right hand and move choke valve to the full vertical position. If the choke valve will not stay open, the your choke needs adjustment. I gave up on automatic chokes long ago and spent $12 to convert to a manual choke - my recommendation.
12-14-2012, 10:45 AM | #15 | |
So I think I will try that during warm up and shut it once warm. as for the dieseling, i did not know that it could bend the valves, luckily i had been doing just that but once or twice i would get mad and just let it die on its own...no more though. i have been playing with the choke and its idle screw a bit at a time and its getting better. Thanks to all for the info. i'm still playing with it and still will have to get my carb relooked at by a competent mechanic once i find one around here. |
