Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 11-29-2012, 02:23 PM   #1
Operatorfailure
66 swb traction problems
My dad has a 66, stock bottom end 350 with vortec heads, thumpr cam, th350 with 2800 stall, 3.73 rear welded up and 29.5x10.5 slicks running high 13s and is spinning 75% of the time at the line. He is switching to drag radials, m&h 275/60-15s so he doesn't have to swap wheels when he takes it to the drag strip. His suspension is bone stock, so for Christmas I am going to buy him some 90/10 front shocks and box in his trailing arms. Anything else we can do for cheap to help him hook up?
Operatorfailure is offline   Reply With Quote
Old 11-29-2012, 04:39 PM   #2
Super73
Super73's Avatar
Re: 66 swb traction problems
Don't waste your money on 90/10, buy some adjustable shocks, even if they are single adjustable. The Competion Engineering 3-way adjustable are also a waste. You want an adjustable shock as track conditions vary. Also, the shock is going to be even more of a benifit if you have a spring more suited for weight xfer.
You also don't need to box the control arm, simply welding 6" sections of the seems every 6" or so will be plenty.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 11-30-2012, 07:36 AM   #3
PGSigns
PGSigns's Avatar
The rear shocks are also important. Has he weighed it front, rear and total? What tire pressures were tried?
JImmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
