Old 11-29-2012, 03:21 PM   #1
pontiac6269
pontiac6269's Avatar
Rear U-bolt torque ?
I bought a 85 Blazer last Saturday and one of the first things I did was remove the 4" lift blocks out of the rear, (no lift in th front). Bought the correct stock size u bolts and they list torque specs on the label as 265 ft lbs for 5/8 bolts. Is this correct? I haven't worked on leaf springs except for shocks on my truck.
Thanks, Eric
pontiac6269 is offline   Reply With Quote
Old 11-29-2012, 04:34 PM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: Rear U-bolt torque ?
140 lb/ft
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 11-29-2012, 06:55 PM   #3
pontiac6269
Thanks, Have another question, do I have to get shorter or a stock type lenth shock now that I removed the 4" lift blocks?
Eric
2001 Ford F350 EC dually 7.3
1981 Chevy C20 to K20 350
1978 Oldsmobile Cutlass Supreme 455 Pontiac
1969 Pontiac GTO 400
Old 11-29-2012, 08:09 PM   #4
68Timber
68Timber's Avatar
I read somewhere once that you shouldn't reuse u-bolts, that they were set for a one time use when you torque them down. I knew that and still reused a set once in a pinch and never replaced them. All I can say is they didn't fail, but I'm not sure what the general consensus is.
John
74 Honda Z50 build
Old 11-29-2012, 08:27 PM   #5
pontiac6269
The u-bolts are new, I was wondering if the rear shocks may be to long without the 4" lift blocks and should be replaced with a stock length shock?
Eric
Old 11-29-2012, 08:38 PM   #6
68Timber
68Timber's Avatar
My mind saw u-bolt, not shock, sorry. If it really does have shocks for a 4" lift, then yes, you do have to replace them.
John
74 Honda Z50 build
