11-29-2012, 07:27 PM | #1 |
What width?
What width rear end fits under a 50 Chev 3100 with good clearance?
Posted via Mobile Device |
11-29-2012, 07:52 PM | #2 |
Re: What width?
What bolt pattern are you after?
11-29-2012, 08:24 PM | #3 |
Re: What width?
11-29-2012, 10:41 PM | #4 |
Re: What width?
If you're going to build/narrow a 9", I would suggest finding your wheels first and match the required width to the offset. The end width will be depicted by the wheel offset. Otherwise a popular swap option back in the day was to install a 55-57 chevy rear which is 60" wide. This site might give you some ideas on others that will work.
http://www.carnut.com/specs/rear.html Posted via Mobile Device I noticed you live in NRH. You are welcome to use my 13 year olds 51 AD for measurements if you like. We live just northeast of TMS in Argyle. Last edited by dadz34; 11-29-2012 at 10:50 PM. |
11-29-2012, 10:54 PM | #5 |
Re: What width?
Welcome Dadz34 from So. Az,
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
11-30-2012, 11:04 AM | #6 |
Re: What width?
Thanks solidaxel! Hopefully I can be an asset.
11-30-2012, 11:45 AM | #7 |
Re: What width?
62 wms is what I came up with on mine. If you are running a 9 and can cut/broach etc , then your wheel choice ( backspace)will ultimately dictate your housing width.
8.8's from Explorers with disc are common as are s-10, camaro, firebird. Pre 69 1/2 ton chevy truck are 62 1/2, but 6 lug. Moser can supply axles for most anything. |
