11-29-2012, 08:22 PM | #1 |
Hard to find HO diff ratio?
I wish I had the money for these! Is this the ratio that is so hard to find?
http://www.ebay.com/itm/HO72-HO52-CH...item416ebf0312 |
11-29-2012, 09:04 PM | #2 |
Re: Hard to find HO diff ratio?
don't see that every day
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
11-29-2012, 09:14 PM | #3 |
20' Daredevil (Ret)
Is it my imagination or do those gears look a bit rough (pinion especially) for new, unused gears? Might just be the picture, or some protective coating....
11-29-2012, 09:55 PM | #4 |
3.90 vs 4.10 is not much of an improvement. Same result can be obtained with 2" larger tires with the factory 4.10. Now a 3.50 would be something special.
11-29-2012, 10:21 PM | #5 |
With my 4.57 I wouldn't mind it.
1971 C20 "Shreck" 1980 C30 dump bed "Ratchett" |
11-29-2012, 10:37 PM | #6 | |
Still, pretty rare to see a set...
- 2010 Silverado - 1984 Chevy M1028 (K-30) - 1969 Chevy C-30 - 1933 Ford Stock Car |
11-29-2012, 11:30 PM | #7 |
Cluster King
I agree with you. I have never seen a new gear set with a finish like that. It looks like graphite spray and the pinion gear does look pretty rough. I would be careful with that purchace and make sure you are getting what you pay for.
11-30-2012, 01:14 AM | #8 |
i think its just the camera the label on the box looks a little wavey on the edge.
1969 chevy c10 lwb stepside 250 6 3 ott 1971 chevy c10 lwb 250 6 with power steering 3 ott 1972 chevy k20 4x4 350/TH350 automatic 1978 chevy Malibu 4dr 305 2bbl (all original) 1979 chevy k10 Scottsdale 350/th350 full-time 4wd(daily driver) |
11-30-2012, 08:11 AM | #9 |
Pretty cool to see,but basically worthless and absolutely non cost effective. That's a huge chunk of change for a ring and pinion and you only get .20 taller gears. If you have 4.56s,just buy a complete 4.10 rear for 1/2 that much (or less) and not go into rebuilding a differential that would likely end up running close to $1000. Just swap out the chunk and go.
