Old 11-29-2012, 10:21 PM   #1
Frkypunk70
Frkypunk70's Avatar
Who is re-popping bed supports?
My actual question is who is making them at a reasonable price? LMC has them but they seem a little pricy. I just want to replace 2 or three that are weak. And because you will never see them and because I use the truck to haul stuff, I just want to cut out the bad ones and replace with cheap new ones. Someone told me I can just use sign post......I am cheap but not that cheap. Thanks
"When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. "
Frkypunk70 is offline   Reply With Quote
Old 11-29-2012, 10:43 PM   #2
Shyguy
Junior Member
Shyguy's Avatar
Re: Who is re-popping bed supports?
You might try GMC Paul's website.
LMC has the measurements in their catalog, you might be able to get some metal and make them.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 11-29-2012, 11:31 PM   #3
Frkypunk70
Frkypunk70's Avatar
I have thought about cutting out the bad and just welding in new material...but it would probably be just as easy to buy the parts...I will check out Paul's ...but if anyone has a easy fix I am open ears. The two or three I need are rotted on the sides and make the bed feel soft in the middle. I am going to take the bed off for this and probably put some bags with schrader valves. I get worried as I keep putting heavier loads in the back.
Old 11-30-2012, 06:35 AM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Mar-K in Oklahoma.
