11-30-2012, 12:31 PM | #1 |
ls motor conversion brackets
up for sale i have these new brackets and mounts conversion kit from cpp for 1967 to 1972 c/10 trucks to fit the gm ls family engines , $150.00 shipped
check out my build thread 71 c/10 step side 5.3 twin turbo http://67-72chevytrucks.com/vboard/s...d.php?t=485320 raul |
11-30-2012, 12:39 PM | #2 |
Re: ls motor conversion brackets
Raul's- do you have pictures of them installed? I'm trying to figure out what setup to do in my 68 when I upgrade to a 6.0. Also, I would appreciate your comments in this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=551464 Thanks, Rob Posted via Mobile Device
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
11-30-2012, 01:31 PM | #3 |
here you go rob !!! in these pix its just the brackets moked on without mounts and the plates that bolt onto engine
12-03-2012, 08:59 PM | #4 |
Raul - do you have the plates that bolt to the motor also?
12-03-2012, 11:30 PM | #5 |
sorry i guess i should've post this also , yes i do and all hardware in its original package !!!!!!!
check out my build thread 71 c/10 step side 5.3 twin turbo http://67-72chevytrucks.com/vboard/s...d.php?t=485320 raul Last edited by raull; 12-04-2012 at 12:18 AM. |
12-04-2012, 10:11 AM | #6 |
Do you have a part number for the LS plates that bolt on to the motor? Apparently there are 3 different versions which place the engine in different positions.
12-04-2012, 10:26 AM | #7 |
there are no numbers on the plates , this is the kit from cpp ,i guess ill call them later to ask
12-04-2012, 01:02 PM | #8 |
mine are the ls1k3 which moves the engine 3 inches foward , here is the link that shows illustrations on all brackets ,
http://www.classicperform.com/Instru...PDF/LS1-K3.pdf
12-04-2012, 06:16 PM | #9 |
Grandpa in the rustmobile...
So what oilpan does this work with?
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
12-04-2012, 06:17 PM | #10 |
So these are only for LS1 engines?..
12-05-2012, 01:56 PM | #11 |
hope this helps , this set up is for ls1 oilpan on pix no# 1 , i was going to use a truck ls motor pix #2 which has a pan that sits even further back with more crossmember clearance
12-05-2012, 02:06 PM | #12 | |
12-05-2012, 02:30 PM | #13 |
Just to clarify...This included the mounts, tubular stands, ls1k3 plates, all the bolts & hardware + shipping, correct?
If so, I think I'll take 'em. Thanks, Ed |
12-05-2012, 11:34 PM | #14 |
that is correct !!!
