Old 06-04-2003, 05:48 PM   #1
ckenwright
ckenwright's Avatar
Emissions test
I tried to get my truck emission tested yesterday and it failed. Apparently I was running a little rich. Max HC allowed was 4.00 at 2500 RPM and I was running at 4.03. At idle max I was running 4.63. Go figure.
ckenwright is offline   Reply With Quote
Old 06-04-2003, 06:03 PM   #2
68_c10_on20s
68_c10_on20s's Avatar
test
if your truck is a 67-72 it should be exempt i know they are here in houston hell i could have a blown 502 in my truck no prob if only i had the mulah...Steve
93 Fleet Budget Build http://s150.photobucket.com/albums/s...zted71/hoopty/
68_c10_on20s is offline   Reply With Quote
Old 06-04-2003, 06:06 PM   #3
ckenwright
ckenwright's Avatar
I have had the truck for about 5 years now and have lived in Texas, New Mexico, Arizona, and Nevada. This is the first state I have been to that I have had to test it. You are only exempt in Nevada if it is 67 or older.
Old 06-04-2003, 07:47 PM   #4
68_c10_on20s
that law blows!!!!
look above...man that erally does suck big time
Old 06-04-2003, 08:11 PM   #5
ckenwright
ckenwright's Avatar
68_c10_on 20's
What town do you live in- in Texas? I'm originally from Dallas which is where this truck was bought new.
Old 06-04-2003, 08:35 PM   #6
68_c10_on20s
city
I live in Cypress its like a Houston suburb about 5 minutes away
Old 06-04-2003, 10:45 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Lean it out a bit, a new air filter and fresh plugs and a little messing witht eh carb adjustments will go a long way on the sniffer.
Old 06-05-2003, 04:07 AM   #8
Phillip Johnson
Phillip Johnson's Avatar
Nothing in Grants Pass Oregon needs to be smogged. My New Yukon is exempt. My 72 and my motorhome is also... In Calif, they exempted everything 73 and older.
Phillip Johnson is offline   Reply With Quote
Old 06-05-2003, 04:18 AM   #9
ddsmith
Glowing since 1978
ddsmith's Avatar
That's pretty sad. I think it's a ricer plot to rid the streets of all the really cool rides so they will get more attention. I find it hard to believe that we allow this to happen. For crying out loud, these trucks didn't even know what emission controls were when they were made. Except for the token California trucks. They don't perform these checks for free. You pay for them and the government gets bigger. The idiots that work here doing emission check don't even look like they can tie there shoes. The bad thing is I have to allow them to drive my vehicle on a tread mill and they suck at it. They can't keep the speed where it needs to be so the test takes forever.
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in
71 Corvette Coupe 454 4 speed
69 Chevy C20 Custom Camper
ddsmith is offline   Reply With Quote
Old 06-05-2003, 08:40 AM   #10
Blue Beard
Blue Beard's Avatar
Change the oil before being tested.....
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 06-05-2003, 08:41 AM   #11
tom hand
CCRider
tom hand's Avatar
If you are happy with the way it runs and you don't want to mess with the carb try this. Create an intentional vacuum leak. Should lean it out enough to pass the test. Just dissconnect a small vacuum hose or remove a plug on a manifold vacuum. It needs to be a small one or the drop in vacuum will cause the carb to go into the power circuit and make it even worse. Have fun!
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 06-05-2003, 09:30 AM   #12
68_c10_on20s
dyno???
what really sucks is they do these test and WONT even give you your rwhp thats what pisses me off i know that machine will tell em,hell it would be worth the 49 bucks then huh....just my 3 cents
Old 06-05-2003, 10:28 AM   #13
Mixup
ckenwright, I live in Henderson and my truck always had a problem passing. I retard the timing and turn the idle mixture screws in until it just about runs and it passes everytime. I just put Classic Rod plates on my truck and I don't have to get tested anymore as long as I don't drive more then 2500 a year. If I get close I'll disconnect the speedometer.
1980 Chevy Shortbed Pickup
1969 Z28 engine
Turbo 350
Mixup is offline   Reply With Quote
Old 06-05-2003, 10:36 AM   #14
Bill72BB
Thats the Hillbilly way
Bill72BB's Avatar
Note to self don't move to Nevada.
BILL
Torrance Calif 90504
Member DUF Club
Member Old Farts Club
72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts
tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion.
" If I knew I was going to live this long I would have taken better care of myself "
Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER....
Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen ,
Bill72BB is offline   Reply With Quote
Old 06-05-2003, 10:53 AM   #15
VTKidder
Vermont, does smog tests on certain vehicles, but with our older trucks, they're exempt. If it had a converter on it from the factory, it has to have one to get inspected. That's about the only rule.
VTKidder is offline   Reply With Quote
Old 06-05-2003, 10:59 AM   #16
Green72GMC
Green72GMC's Avatar
Those tests suck. None of the inspection stations do it in this town on the newer vehicles anyway. They just do the horn, lights, and few other things, I've seen people run straight pipes and pass.
1972 GMC SWB, 305 powered
1980 diesel VW pickup, Needs a Heart Transplant
1997 Toyota Taco
The Second Amendment is in place incase they ignore the
others.
Green72GMC is offline   Reply With Quote
Old 06-05-2003, 11:57 AM   #17
TooMany2count
Who's in CHARGE??????????
TooMany2count's Avatar
Simply change the plugs(if it needs them), oil & filter, pull air cleaner out, & then remove PCV from valve cover & just let it lay on top of it. what this will do is, bring cleaner air into the motor. the oil is contaminated with gasoline, which will make you have HIGH HC's so change it. Removing the air cleaner & the PCV will also allow more clean air into your motor. My 84 Burb flunked big time too because of HIGH HC's & a emissions guy I know told me to do these things & I passed w/flying colors. As long as it says you PASSED, thats all they care about...joe
Send a card to a soldier in Iraq
My Music PlayList
Large Marge
Donate Blood,Plasma,Platelets & sign your DONORS CARD & SAVE a LIFE
TooMany2count is offline   Reply With Quote
Old 06-05-2003, 02:59 PM   #18
Chevyguy111786
In Texas, the law is if your vehicle is 25 years or older you only have to have safety inspection. This is what i have always heard. Check with your laws for Houston. I think an inspection station is tryin to make a quick buck. Our 89 Isuzu Pickup failed 3 times....for stupid stuff. 1st time for a plug in the tire...they couldn't put it on the dyno. 2nd time they wouldn't put it on the dyno because the tail light lense had a crack in it. 3rd time it actually failed on the dyno. Took it to our mechanic and he couldn't figure out why it failed. So he gave us a sticker. But check the laws because i know in North Texas you only have to have inspection. It'd be worth a search or to on the internet or a phone call.
Chevyguy111786 is offline   Reply With Quote
Old 06-05-2003, 03:40 PM   #19
krue
Designated A-hole!
krue's Avatar
Emissions, what's that!
Just another reason to live in Mississippi!
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 06-05-2003, 04:02 PM   #20
ckenwright
ckenwright's Avatar
Since I am in the Air Force I have to register my truck on base. In order to get my truck registered, I have to comply with state law even though I have out-of-state tags. They tell me I have to do smog my truck so I have to smog it.
Thanks for all the input, I think I am going to put a dwell meter on it, adjust the timing and give it a tune-up after I adjust the carb. Then maybe for safe measure I will take out the filter before I smog it.
