06-04-2003, 06:18 PM | #1 |
1967 3/4 ton front a arm
I need complete lower "A" arms for a 1967 Chev C-20 3/4 ton truck. I would prefer new over rebuilt. (this includes lower ball joint and controll arm w\bushings)
06-04-2003, 06:36 PM | #2 |
Um....I think you'd be better off getting 3/4 ton lower control arms without the center bars and ball joints, call up your local parts store that supplies Moog parts, and order the center bars and lower ball joint separately. You're not going to find ones in good shape when they're off a parts truck. You'd want to replace them anyway...
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
06-05-2003, 09:34 AM | #3 |
I have a 1967 c20 pickup long box. no front clip and the cab is straight. Needs alot of rust repair. The front control arms are pretty oil and grease covered for i would assume that they would be rust free.
i will check if your interested in the pieces |
06-05-2003, 09:57 AM | #4 |
LMC has 3/4 ton arms
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html " TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410 </A> |
