slow windshield wipers
so, now that it is raining, the windshield wiper motor seems to be pretty slow. the normal mode seems slow and when switched to the faster mode, there isnt too much of a spped difference. It is faster but not fast enough..... is it the motor or can it be something else... any tips or tricks to make it faster
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP SOLD 1972 chevy c10 |
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: slow windshield wipers
To try something quick & easy, lube the linkage pivot points just under the slots in the cowl. If that doesn't help, it could be the motor.... aside from swapping to a new motor, I'm not sure how you'd prove that.
You might also try cleaning the electrical connections to the motor. If they're not clean, electrical resistance might cause the motor to run slower.
#3 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=532568 You also might consider a relay similar to the head light relay upgrade. Just a thought. |
Take a good look at where the shafts come through the cowl. I found that mine had shifted slightly and was causing the shaft to rub on the cowl. I readjusted the cowl and gained some clearance and the wipers went back up to normal speed.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
The Older Generation
My luck wasn't as good as Pritch's. I ended up changing the motor in the White '67. LockDoc
thanks, I will take a look at it
