Is there a trick to making the seat belts retract better?
The driver's side belt will retract with a quick snap of the belt but the passengers side will not. Is this a common issue? Is there some sort of easy fix for this issue?
Thanks. |
Re: Is there a trick to making the seat belts retract better?
it's 25 years old, replace it.
![]() Join Date: Nov 2012
Those stupid seat belts are NOT cheap either. LMC seems to want nearly $100 for just one. At least I think it is the price for just one. The LMc website is not very specific, but the word "set" is not used.
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed http://67-72chevytrucks.com/vboard/s...d.php?t=584617 PROJECT JIGSAW 1967 GMC C3500 GREAT WHITE 1986 Blazer M1009 |
Good luck getting the mounting bolt out without twisting it off!! I have busted knuckles on a few occasions replacing belts,then you gotta drill it out.But hey,if everything went easy,you would have nothing to crab about eh!!!!
1977 Chev C30 454/465/14ff DRW 1974 Chev C20.350/465/14ff " Rock n Roll ain't noise pollution" ![]() |
I had a problem since 1985 on my GMC with this issue. Finally (after 27 years) I replaced them with a set of non-retractable belts. They're sometimes a PITA to adjust, plus they just hang when released but at least I know they will stay intact in the event of an accident. Just don't trust the retractables anymore.
Mine are weak as well but I trust them. Anytime I go over a bump fast and my truck jerks in the air they lock. If I have to panic brake they lock. I trust them period. The internal springs are weak for sure for the retract but I'm thinking of taking them apart and putting springs from a new belt into the old
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
78K & 79C Jimmys
check the plunger going threw the sill
seen them fulla dirt,over spray ,rubbing,maybe the seat belt isn't centered in the hole? pop of the cover for cleaning too
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
Mine seem to tighten across my abdomen as I drive along. If you didnt want a pee at the start of the journey,youre desperate by the end......
Wd40
$100 each, $200 plus some shipping, it's your life, two bills is not expensive at all, especially after you kiss the steering wheel at 30+ mph..
winner winner chicken dinner!! i need to order 4 for the ole cc.. but i need bright red, not facotyr red (maroon) bright red |
![]() Join Date: Feb 2009
https://www.seatbeltplanet.com/webbing-replacement/
Haven't investigated yet, but saw them mentioned in another similar thread.
-Don- '66 ![]() '77 ![]() '80 ![]() '04 Denali XL '05 DMax CCLB 4x Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf ![]() |
