12-01-2012, 02:44 PM | #1 |
drivers side OEM mirror arm, ignition switch w/key, 305 parts
I have a 65 OEM mirror arm appears in good condition $30 shipped
Also have 65 GMC truck with a 305 in it if anyone needs parts let me know what you might need ignition switch with key $30 shipped |
12-01-2012, 09:05 PM | #2 |
Re: drivers side OEM mirror arm, ignition switch w/key, 305 parts
12-04-2012, 12:16 AM | #3 |
Nobody needs this? mirror arm
12-04-2012, 05:45 AM | #4 |
I need it, but tabs are due on the 85 diesel burb and I can't afford it. Just curious...is it the same for a 60?
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
12-04-2012, 08:36 AM | #5 |
Not sure but I think so
Posted via Mobile Device |
12-04-2012, 11:44 AM | #6 |
60 used a cast iron mirror arm. Design changed to another cast arm in 61 and the tubular design came out in 62. I have 60 & 61 driver side mirror arms if interested.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
12-10-2012, 12:57 AM | #7 |
ttt
12-18-2012, 11:40 AM | #8 |
If need 305 parts let me know if to high let me know make offer
