12-01-2012, 09:23 PM | #1 |
where do I get Rocker panel caps/plugs
Who knows where to buy replacements for the plastic caps/plugs that go in the holes in the front of the rocker panels? I need some to put in the holes of the panels I put on my cab that Im rebuilding. Also was thinking of using a properly sized hole saw to drill a few (maybe two) holes into the back of the rocker in a few spot so that I would be able to put in some of these caps and then pull them out periotically to clean out and or dump oil inside the rockers as rust prevention. Good idea? opinions? Thanks for any info and or feedback.
12-01-2012, 09:32 PM | #2 |
Re: where do I get Rocker panel caps/plugs
gmc pauls sell,s them
12-01-2012, 09:48 PM | #3 |
Thanks for the reply. I looked on the site but couldn't find them listed. Could you tell me what to look under? thanks
12-01-2012, 09:54 PM | #4 |
they are in with the patch panels, i just looked . they cost .95...
12-01-2012, 09:55 PM | #5 |
Here you go:http://www.gmcpauls.com/new_page_8.htm
Why not spray the inside with undercoating? Posted via Mobile Device |
12-01-2012, 10:16 PM | #6 |
Thanks for the link. Whatever you wanted to put inside there whether it be paint oil or whatever you need a way to get in there after its al welded up. I thought maybe one about halfway and another toward the back. Every one of these Ive ever had colected sand inside the rocker and rotted through from the inside out along the bottom. I think it find its way through the top between the spot welds where the door gasket sits.
12-01-2012, 11:25 PM | #7 |
Go to any good auto body store and get some 3M Rust Fighter I to spray inside your rockers and anything else you can get access to. It's a non hardening corrosion protection coating for all internal cavities. Aerosol can or quart jar with a special applicator that hooks up to your air hose. The latter is by far the best applicator for getting in tight places like rockers. Has a 36 inch wand that can spray 180-360 degrees. You can run it up in between the bed and fender to help prevent corrosion too.
12-02-2012, 07:41 AM | #8 |
1969 Custom 30 wrecker
Got mine from classic parts.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
12-02-2012, 12:11 PM | #9 |
Just looked up that 3M rust fighter on line. Sounds like awsum stuff , Im suprised I never heard of it before. Has anyone else ever used it?
