12-02-2012, 09:52 AM | #1 |
Which Lugs?
I am getting ready to swap my axles from 6 lug to 5 lug and have a pair of Moser axles getting ready to go in. My question is which lugs do I want? These say "typically used with disc brakes (7/16" - 20 x 1 3/4"), is that the size I want? Wheel wise I will be going with Weld Star Pros.
12-15-2012, 01:19 PM | #2 |
Re: Which Lugs?
SOLD -77 CHEYENNE SWB, LS SWAPPED -1976 SILVERADO YUBA GOLD/NEUTRAL (2-TONE) |
12-15-2012, 01:48 PM | #3 |
Re: Which Lugs?
Thanks!!
Posted via Mobile Device |
12-15-2012, 02:20 PM | #4 |
Re: Which Lugs?
You can buy the studs from generally-local stores like NAPA. Other locals should supply them as well, maybe cheaper. The stud size from '71-upwards is 1/2-inch, 20 threads/inch, and .535* knurlsize (shoulder-size that presses into axle-flange-holes). *.535 should work just fine in a .530 knurlsize-diam. hole* NAPA price is approx. $2.50 each. Be sure to get grade 8!
As far as what lugnuts to use, it is generally best to check with wheel-mfg., as tapers vary from wheel to wheel. HTH, sam |
