Old 12-02-2012, 10:30 AM   #1
Swed-Chevy
Swed-Chevy's Avatar
1983 GMC cooling system.
Hi,i need to replace the radiator who is leaking.Om my car both hoses
to the heater core for cab came from the engine,one from manifold and one
to the water pump.
But was thinking one off these hoses maybe should be connected to the radiator original ??
Chevrolet Cheyenne K2500HD 1992.350tbi.4L80E.
GMC Sierra Custom C1500 1983.
Oldsmobile Dynamic 88 -65.
Volvo V70 -02 and BMW 523i T -99.
Harley FXDF -08 and Harley FXDB -10.
Honda Dirtbike Dominator -97 and a couple of tractors.
Swed-Chevy is offline   Reply With Quote
Old 12-02-2012, 10:51 AM   #2
motornut
78K & 79C Jimmys
motornut's Avatar
Re: 1983 GMC cooling system.
Hi ,i find you get better/heat sooner
up here I think thats the better way
If you are spending more time getting heat out of the cab,
one from the rad(southern temps)
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 12-02-2012, 11:28 AM   #3
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Mine had the return going directly into the radiator. My aftermarket intake supplies the heater core. From a dead cold start, in less than 1 mile, heat is coming out!!
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 12-04-2012, 03:20 AM   #4
Swed-Chevy
Swed-Chevy's Avatar
Thanks for your anwers.It,s about -70 F here now so i wait with the radiator mod.The radiator works yet but leaking a litte just under upper connection to thermostat.
Old 12-04-2012, 09:12 AM   #5
gchemist
gchemist's Avatar
You can run the heater return to the water pump. Supply is more important. The closer to the thermostat, the better. You live in a very cold climate, running the return to the water pump is better. If you do route return to the radiator, route it to the left side (lower radiator hose to the water pump).
Old 12-04-2012, 09:43 AM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
-70F? may want to (block heater) plug it in...
make sure your mix is good down low too
no leaks even better heat,you will end up with air pockets
John
Old 12-05-2012, 05:02 AM   #7
Swed-Chevy
Swed-Chevy's Avatar
A couple of years ago it was -88 F for a week so the mixture of anti freeze are very important.All our 5 water cooled vehicles have block heaters and the cars we use most also electrical cab heaters.
