Old 12-02-2012, 12:04 PM   #1
jonnyNITRO
Trans codes 0740 & 0785 help
I realized this is the better topic for this question...
I recently finished a swap install. All is well except these two codes that keep popping up. 0740 & 0785.
I've checked the wiring and no shorts. Tested the pins for the 2-3 shift solenoid (T, E, and S). All good resistance values. Have the VSS plugged in, brake switch is hooked up (normally closed) circuit.
PCM was reprogrammed by Brendan @ LT1swap.com
Process of elimination...
Just confused as to where to go next.
Any ideas (logical ideas)?
Graphic Design / Photography
3D Automotive Renderings
jonnyNITRO.com
jonnyNITRO is offline   Reply With Quote
0740, 0785, 4l60e, code, trans
