Old 06-04-2003, 10:34 PM   #1
GMC JUNKIE TOO
THE QUICKER FIXERUPER
GMC JUNKIE TOO's Avatar
auto meterwiring ?
I bought a covans classic insturment panel and a set of auto meter gauges I have figured out all the wiring except for the fuel gauge. The instructions say to hook up a wire from the ignition switch to one pole the fuel tank ground to one and the wire from the sender on the tank to one. when I used a test lite on the insturment cluster harness with the key on I get a brite lite on wire #7 and a dim lite on #8. so which wire is which?
Thanks in advance Ben (im not evil I just wanted to use the new smilie)
GMC JUNKIE TOO is offline   Reply With Quote
Old 06-05-2003, 01:40 AM   #2
GMC JUNKIE TOO
Anybody?
Old 06-05-2003, 04:03 AM   #3
Mudder
Mudder's Avatar
You can find the correct sender wire down under the fuse box (tan wire) where it comes from the tank. Thats where I connected to mine. The harness has two tan wires I believe without looking.
Mudder is offline   Reply With Quote
Old 06-05-2003, 08:48 AM   #4
Blue Beard
Blue Beard's Avatar
Check out GMC Pauls website under the tech section.
He has info on the old wires and with the new gauges.
There are 2 tan wires.
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
