Old 12-02-2012, 06:38 PM   #1
rgunlock
rgunlock's Avatar
removing shifter from 4-spd on 78
Working to remove cab, but not enough clearance in my garage to get over shifter, so it must come off. Those things that look like set screws aren't. How do I get this off? Thanks - Rick
Rick
78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel
71 GMC C25 350/TH400 - Project Angie
59 Chevy SWB Stepside (next in line? Not sure now )
2001 GMC Sierra K2500
rgunlock is offline   Reply With Quote
Old 12-02-2012, 07:38 PM   #2
PaRedneckRiders
Re: removing shifter from 4-spd on 78
The half moon looking metal ring with a small cutout on top where the shifter comes through, Push down on it and turn it counter clockwise then it will pop up out and so will the whole shifter. It is easier to remove and then put back in if the trans is in N when you first remove it.
PaRedneckRiders is offline   Reply With Quote
Old 12-02-2012, 11:11 PM   #3
rgunlock
rgunlock's Avatar
Thanks for the tip. I did get it out. Here is a picture that helps make it more clear to the next guy. The things that look like set screws are actually just the posts that hold this cap down. You push the middle part with the rounded top down against a spring to release tension so you can twist the cap.
Rick
Old 12-03-2012, 09:43 PM   #4
Mike C
Mike C's Avatar
Great pic Rick. That should help a lot of people going forward!
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
