motor mounts?
anyone have a truck with an original inline six and tried to to put a v8 in but the mounts didnt work so went with the inline brackets? i tried it! the brackets work but the motor sits back a little!
Re: motor mounts?
You are not the first by a long shot. The hassle is that nothing lines up. All the factory and aftermarket parts are designed for the corrct positioning of the motor. Exhaust and clutch issues seem to be the biggest. Here is a post on frame stands and mounts.
http://67-72chevytrucks.com/vboard/s...t=motor+mounts Post 18 has a picture that really tells the story.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Re: motor mounts?
I used inline 6 mounts to put my 5.3 liter in my 68. Yeh, it moved the engine back quite a bit. I used a lokar shifter cable with my tranny, so no problem. My exhaust dumps right in front of the tranny crossmember though, so it makes a real tight 90' turn down and under. Will fix that soon though. No other problems though. Oh, had to shorten the driveshaft too though.
Re: motor mounts?
My truck had V-8 mounts, and I had I-6 mounts laying around from a previous truck, and put them in, ha ha. I did it for just what you say, move the engine back. An HEI distributor will still fit, and you can pull it in and out.
I did all custom linkage for my transmission anyway, wasn't worried about a new driveshaft, and did my own exhaust too. The most interesting part about it, I used a 4-speed Saginaw transmission (I'm sure a 3-speed would work the same). If you mount the transmission at the tailhousing instead of the bellhousing, you can use an automatic tranny crossmember and it lines up with factory holes in the frame. Or mine did anyway...
Super Blue - 1968 C-10 Short Stepside
Fastburn 385, 4-Speed Sag. on the Column, Coleman 9" Floater w/Detroit TrueTrac |
