Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 12-02-2012, 11:16 PM   #1
hotrod 80
mini truck racer
hotrod 80's Avatar
trans cooler in radiator
I am thinking that having a trans cooler in the radiator will make the truck more consistant as the motor and trans will be at or around the same temp and /or warm up together . I have a seperate trans cooler now . How much difference could this make ? Who runs a seperate and in rad cooler ?
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 12-02-2012, 11:36 PM   #2
vidman
vidman's Avatar
Re: trans cooler in radiator
I run seperate coolers for transmission, engine oil and coolant.Just think it all works better for me
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline   Reply With Quote
Old 12-03-2012, 12:32 PM   #3
Marv D
Registered Truck Offender
Marv D's Avatar
Torn. I have #2 in SuperPro telling me to put some HEAT in the trans/converter by sitting on he brake against the converter for a good 45 seconds BEFORE pulling out of the staging lanes.
And you have the trans builders saying NONONO NO!! Heat kills transmisions.
Who do we listen to,,, The guy that puts together <0.001 packages consistantly,, or the guy we pay to rebuild the trans?????
I don't know, I just wanted an excuse to play with the gif's LMAO
Seriously,,, I run as much cooling as I can. I have one of these mounted under the bed because I don't have a in-radiator cooler. I have a trans temp gauge in the dash and I see temps of around 190-200 in the heat of summer after 5-6 passes (with short cool down times) On the street wheere I'm not against the brake or driving through the convertor at the top end,, it rarely comes off 140
http://www.summitracing.com/parts/de...0/media/images
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 12-03-2012, 04:12 PM   #4
hotrod 80
mini truck racer
hotrod 80's Avatar
I run a seperate in the Yellow truck . I am considering running in rad in the white one . I have a seperate cooler and the radiator will be more expensive . The "heavy hitters" around here have them as i have been eyeing alot of cars learning lately .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 02-17-2013, 10:33 PM   #5
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
I run a trans cooler built into my Wizard radiator. So far so good.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 02-18-2013, 03:56 PM   #6
Chris92
Chris92's Avatar
You will be fine either way. It's all about consistency in what you do each time. I build mine with the most cooling I can get because I can control it better that way. If it's under cooled there is not much you can do.
Do it separate and put a switched fan on it.
Just my 2 cents.
Chris
Chris92 is offline   Reply With Quote
Old 02-28-2013, 11:04 PM   #7
dbmx66
i put mine where the bed floor used to be, with its own little 8 inch fan on it.
dbmx66 is offline   Reply With Quote
Old 03-01-2013, 04:45 PM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I run a seperate cooler, but I only advocate doing that if your are going to run a GOOD multi pass unit with fans etc....not one of the Jeggs 1 pass fin coolers.
If I wasn't running a good aftermarket cooler, I'd most likely have it in the radiator...but nothing is stopping ya from running it rhough the rad AND a good cooler. (MY rad no longer has provisions for the cooler)
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
