Old 12-03-2012, 01:07 AM   #1
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Standard 3spd saginaw or something else??
Looks different that some pics I've seen of them (with the fins on the bottom and the shape of flange that bolts to bellhousing) and this is hooked up to a custom shifter on the floor thats why I wonder.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 12-03-2012, 10:55 AM   #2
Portmod7
Portmod7's Avatar
Re: Standard 3spd saginaw or something else??
Judging by the (3) shift rods/arms, I'd say it's either a 4 or 5 speed. But I've got no idea what it is. I can't think of any 4-speed pictures I've come across that look like that?
Also, is the lower RH bolt into the bellhousing just missing, or does the tranny hole not line up with the bellhousing hole? That may be a good clue as well... It appears it was mounted off the tailhousing in its previous application too, didn't even pull the mount before they put it in.
Super Blue - 1968 C-10 Short Stepside
Fastburn 385, 4-Speed Sag. on the Column, Coleman 9" Floater w/Detroit TrueTrac
Portmod7 is offline   Reply With Quote
Old 12-03-2012, 11:02 AM   #3
Vintage Windmills
Vintage 4x4s
Good eye on the bolt being missing, I'll check that out some more. This is/was a 3 on the tree column shift 250 I6 truck. Also, there is a little sensor with wires running out on one side of the trans.
Old 12-03-2012, 11:13 AM   #4
geezer#99
geezer#99's Avatar
It's a 4 speed o/d that gm used. Based on the chrysler A833. You can tell by the severely bent shifter arms.
Old 12-03-2012, 12:10 PM   #5
geezer#99
geezer#99's Avatar
Here's some more info on them.
http://www.customclassictrucks.com/t..._transmission/
Old 12-03-2012, 12:51 PM   #6
RichardJ
Muncie and Borg Warner car 4spds have the reverse shift arm in the tail housing. Saginaw car 4 spd has the reverse shift arm in the side cover along with the 1-2, 3-4 arms. Chrysler A-833 4 spds have the reverse arm below the side cover.
Chrysler A-833 OD trans has the 1-2 shift arm pointing up in the normal fashion, but the 4-3 arm points down. I think that is the only way to identify the OD trans from the regular 4 speed A-833.
Chrysler started using that OD trans in their cars in the '70s and then in Dodge and Chevy trucks in the '80s.
If memory serves, Chevy used that trans with two different bellhousing patterns. Neither bell had provisions for side mounts. I think they used a bell with the dodge pattern and sometimes with the Chevy pattern. Below is a Chevy alum bell with Dodge pattern.
Your trans may be hanging on with two bolts.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 12-03-2012, 01:04 PM   #7
RichardJ
I have a 18 spline version of the A-833 in my '69 Roadrunner. The 18 spline is a conventional 4spd with 1:1 4th gear. The gears are nearly straight cut so it's louder than the truck SM465 in my '67. The 18 spline A-833 was Chryslers answer to the Muncie M22 Rock Crusher only bigger.
Old 12-03-2012, 01:52 PM   #8
grancuda
grancuda's Avatar
I have been looking for this set-up for my daily driver '72 SWB.
grancuda is offline   Reply With Quote
Old 12-03-2012, 02:14 PM   #9
Vintage Windmills
Vintage 4x4s
Thanks, i knew there were guys here that could help! Glad I checked- now i won't scrap it. It sounds like a good alternative to the T5 to get OD. Any chance I could get a tailhousing for a 4x4 to fit this? Was this offered in 80's chevy 4x4 trucks?
I'm guessing the 2 bolts wasn't an issue with the little 250 I6.
Old 12-03-2012, 04:51 PM   #10
grancuda
grancuda's Avatar
Should be able to get a tailshaft/housing from a Dodge 4x4 to connect to a transfer case, maybe.
