1970 Daily Driver
Sound Deadening like Dynamat
I saw a thread the other night of a guy saleing sound deading with equal preformance a dynamat but with out the name or price. I can not find the thread for the life of me. Can anyone help me out with a link?
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. |
Re: Sound Deadening like Dynamat
Look up raammat
http://www.raamaudio.com/ As good if not better than dynamat. Used it in my latest build and much easier to use. Highly recommend. Posted via Mobile Device
68 c20 build: http://67-72chevytrucks.com/vboard/s...d.php?t=358130 Club longbed ...cause girls like'em long!!!!! |
Mark ----------------------- Crash's 69 4x4 SWB Crash's Roof over Lake Home Crash's 1988 Land Cruiser Build |
A lot of guys are using the rubber roofing stuff , it's the same product as Dynomat but just a little thinner and no aluminum surface. Though it's some what thinner , you can double layer it. It's a whole lot cheaper too.
I will be doing the roofing product when I do mine. Some Lowes carries it, other than that a roofing store. Its a peel and stick product, as in peel off the paper and it sticks like heck, I have done roofs (houses and commercial buildings) with it. You can get a whole roll for like $50, its 40 inches wide by 50 feet. They also have smaller flashing size rolls that are 9 or 12 inches wide by 50 feet. I think you can get the peel and stick flashing type with aluminum on it. Some areas of the country call it ice and water shield I believe. For you poor souls that live where you get snow build up on your roofs.
I just remembered there is a window wrap product that has aluminum on it. Its for when you are installing a new window in a new house, you line the opening with it before you set the window, and /or put it over the nailing flange of the new window.
Toys/projects Many toys, not enough time to play! My youngest son and I picked up a 69 Chevy C-10 on 1/7/22, this is my second 69, it was 10 years ago that I had my other one. So I’m back!!! ![]() |
Quit if it's not FUN!!!
#7 | |
Great now he can. |
Try Fatmat or Fattmat, I got mine from them very happy with the product and much! cheaper that dynamat.
Fatmat is asphalt based and loses adhesion when the panels get cold ( ie winter). Rhinomat and Dynamat are both EDPM rubber and the adhesion is not affected by temperature.
No offence but I think its a little colder in Canada, and I have not had any adhesion problems with the Fatmat.
i used hushmat in my last project, worked great
#12 | |
needs more $$$
1970 2wd Blazer |
#13 |
![]() Join Date: Jul 2012
I used FatMat. Easy to work with, seems like good stuff
Posted via Mobile Device |
#14 |
I was walking through Westlake/Ace hardware the other day looking for some plastic tubing for an aquarium and walked by the insulation and saw a roll of some stuff that looked VERY similar to Dynamat, now I doubt that it's the same stuff, but insulation is insulation right? It doesn't have adhesive on one side, buuuut I imagine with some spray on adhesive you can make it work. This is an option I am considering when it comes time to re-upholster my truck
Who cares if it's not dynamat or some other name brand sound dedener? If it works, it's going to be under carpet anyways ![]()
1970 C20, SM465, Eaton Ho52, HD coils, NO PB/PS/AC, 250 I6, Wood bed. All original minus a tune up! http://67-72chevytrucks.com/vboard/s...d.php?t=545486 Gentlemen wear a bow tie. |
#15 |
![]() Join Date: Feb 2001
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
#16 |
![]() Join Date: Apr 2011
I went through all of this research this summer when I did my cab - there are as many opinions out there on this stuff as there are truck owners, it seems....anyway, the first thing I'll say is that I used Raammat and was very happy with it. Secondly, and I'm going to shout here, YOU DON"T NEED TO COVER EVERY SQUARE INCH WITH A PRODUCT LIKE THIS. The function of the metal/adhesive products like Raammast is to dampen vibration, and you only need to cover 25-50% of the sheet metal to accomplish that. However, to truly quiet your interior, a product like this isn't enough.
You should put down a mat product like this first, then a layer of isolating foam (I used Ensolite, available from Raam Audio), and lastly, mass-loaded vinyl, which is a heavy product that is what actually keeps sound from passing into your truck. This is the stuff they use when they build recording studios. It's not the easiest stuff to work with, mainly because of the weight, but once you get it in it really deadens sound. MLV is hard to source, again because of the weight the shipping can be costly. Insulation supply houses often carry it. It comes in rolls that are 4'x20', which is enough to do 2 truck cabs. Pics of my interior project can be seen here, with all 3 steps discussed above: https://picasaweb.google.com/1102505...51425959656194 Good luck! |
#17 |
Hybrid67
fatmat is my choice, but I've used the stuff from lowes that's really designed for ductwork and comes with the aluminum backing. Cost about 35.00
Keep em' Running! ![]() All show.....no go ![]() |
#18 |
i also had great results with the stuff from lowes very easy to work the contours and easy to cut with a knife no adhesion issues.
*SOLD* 1968 Chevy SWB Fleet 350/350 combo Tach/tilt/buddy buckets Bagged/18" Wheels Black on Black ![]() Project "Pandemic" the Farm Rat 1927 Chevy Capitol Truck Rat rod '30 Model A Frame Dual Carb 5.3 LS http://www.67-72chevytrucks.com/vboa...d.php?t=804162 2007 GMC 4 DOOR 2WD BUILT 5.3 STAGE 3 CAM 93 TUNE LIFTED 22X12 WHEELS 33" TIRES 2023 Jeep RENEGADE Wifes ride |
