Old 12-03-2012, 04:42 AM   #1
c10boob
c10boob's Avatar
Upper Control Arm Installation
I am replacing the ball joints and bushings to the upper control arms on my 71. Obviously the shaft can be set either to the left or right dependent on how many turns are given to each bushing bolt (which to my understanding needs to be torqued to 140 ft. lbs.)
My question is: should I do my best to center the shaft within the control arm by giving each bushing bolt an equal amount of turns or am I messing with the alignment somehow?
All suggestions on how to properly do this are appreciated!
c10boob is offline   Reply With Quote
Old 12-03-2012, 10:25 AM   #2
1972SUPERSB
1972SUPERSB's Avatar
Re: Upper Control Arm Installation
I just did mine about a week ago. What I did was start the bushing on each end and give them equal amount of turns with my impact. Then once I was close to Completly tightned, I measured from center of hole on shaft to the edge of the inner part of control arm where bushing is. Just make sure the measurement is the same on both ends. I will be getting mine aligned soon at the alignment shop
Jeff
1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt
1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior
1972SUPERSB is offline   Reply With Quote
Old 12-03-2012, 11:19 AM   #3
no moa
no moa's Avatar
subscribed.
I put mine together but haven't got the motor in yet to get the weight on the front end. But i'll be darned if i can get them even on both sides. It was a pain to say the least.
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently.
http://67-72chevytrucks.com/vboard/s...d.php?t=451950
1971 c10 step 250 3 OTT
1969 c30 TOW-MATER. 307 4 speed, holmes 440 body.
http://67-72chevytrucks.com/vboard/s...d.php?t=451082
2006 CTS-V LS2 6spd.
no moa is offline   Reply With Quote
Old 12-03-2012, 11:29 AM   #4
1972SUPERSB
Yeah it is not an easy task. I was using wrenches at first. It worked but was pretty tough. If you have an impact it will work much better not sure of the size of the socket. You will need a big set of channels locks also to old shaft from spinning. I know the lower bushings was a 1 5/8
Jeff
Old 12-04-2012, 12:50 AM   #5
c10boob
c10boob's Avatar
Ok.. so I marked one side of each bolt and began giving them one turn at a time, then tightened up the rest with a quarter turn from the wrench (going back and forth each time). I then tightened them up to 140 ft. lbs. once I installed the control arm into the truck and it turned out centered (though I'm sure it's not perfect).
My thought is that any slight imperfections in the alignment can probably be adjusted by the tie rod.
