Old 12-03-2012, 02:19 PM   #1
dukcaln
dukcaln's Avatar
72 Drop ???
so if I reverse my leaf springs in the rear, below the axel vs on top... what will it equal as far as inches lower for the rear..... as it stands, my rear sits about 1 1/2 to 2" higher then the front?
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP
SOLD 1972 chevy c10
dukcaln is offline   Reply With Quote
Old 12-03-2012, 02:26 PM   #2
CC69Rat
CC69Rat's Avatar
Re: 72 Drop ???
About 3.5-4" drop. Depends on how you do it. (thickness of the tube of the axle at the very least. )
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 12-03-2012, 06:54 PM   #3
dukcaln
dukcaln's Avatar
Re: 72 Drop ???
so doing that and cutting a coil out of the fron should give me an equal drop.... fairly cheap way to lower the truck?
SOLD 1972 chevy c10
Old 12-03-2012, 09:20 PM   #4
Mike C
Mike C's Avatar
Re: 72 Drop ???
Thickness of the tube (3") plus thickness of the spring and the perch height off the housing (about anothe 2 1/2") so figure 5".
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 12-03-2012, 09:24 PM   #5
CC69Rat
CC69Rat's Avatar
Re: 72 Drop ???
1 coil would usually be 2" drop... maybe a little more. What if you did 2" drop spindles and one coil? It would be around 4 up front and 5 rear.
Chad
Old 12-03-2012, 09:37 PM   #6
Mike C
Mike C's Avatar
Re: 72 Drop ???
Yes, that is a fairly efficient way to drop the truck as far as $ go. But to get the front down 4" or so to match the rear drop really requires spindles IMO. I am doing the flip in my '69 and converting to disc brakes which means I had to buy spindles. So, 2 1/2" spindles and 2" springs in front and flip in the rear. I have an additional 1 1/2" shackle drop if I need it.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 12-04-2012, 01:40 AM   #7
dukcaln
dukcaln's Avatar
Re: 72 Drop ???
I want to just flop the rear under the axel and then drop the front as needed to level out. So maybe a coil or two removed from the front
SOLD 1972 chevy c10
