Old 12-03-2012, 06:32 PM   #1
rwade
rwade's Avatar
Electric or mechanical fan?
I am putting a 6.0L in my 72 Chevy truck. It will have a cam in it. This is a show truck that doesn't see many open road miles, just shows. I'm wondering if the electric fan is the way to go, or just better for cosmetics. And will the stock alternator handle the increased load? Or go with the low maintenance, old faithful mechanical fan (that if used would Probly dissaprear in my fan shroud). I realize the electric would save me about 15 horsepower. Opinions? Thanks
rwade is offline   Reply With Quote
Old 12-03-2012, 09:09 PM   #2
bohmankid
bohmankid's Avatar
Re: Electric or mechanical fan?
Run a relay with the electric fans and you won't have a problem with the alternator. The electric fans use less power because they are only on when needed. It's even nicer to get two speed fans. Electric fans look more neat and don't require a fan shroud. So, more space. I use two 14" electric fans. They work fine. If you're climate is VERY hot, like in Arizona or southern states, stick with the stock clutch fan. But since it is a show truck without seeing miles, go with electric. Unless the price of the electric fans makes you change your mind, lol.
bohmankid is offline   Reply With Quote
Old 12-03-2012, 11:30 PM   #3
mooseknuckles
mooseknuckles's Avatar
electric fans are the only way to go....
mooseknuckles is offline   Reply With Quote
Old 12-04-2012, 01:11 AM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Most swaps use an electric rad fan unless trying to be super low budget, and most new cars are coming with electric fans at this point. Excluding the occasional failure due to poor wiring or lack of relay use, electric fans really don't burn motors out that frequently, and its doubtful you would ever see a real reliability difference in the trucks life.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 12-04-2012, 04:31 PM   #5
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
had mine on the truck for 3yr or more now...and were made for our trucks
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 12-04-2012, 04:41 PM   #6
OldCreek
OldCreek's Avatar
I like being able to control the on/off temp of the fans with these LS motors. Half the time they don't even come on...
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 12-04-2012, 06:08 PM   #7
rwade
rwade's Avatar
Kurt, who mades the fan/shroud you have? Works with factory radiator? What could I expect to spend on a set up like yours? Thanks for the input. Too many choices! LOL
Old 12-04-2012, 06:12 PM   #8
rwade
rwade's Avatar
One more question for you Kurt. I see you are running 3:73 gear in the rear, I'm going to run a 16" wide tire and was wondering how it hooks up? Maybe 4:10, or 4:56 for me. Your thoughts?
Old 12-04-2012, 10:45 PM   #9
68GMCCustom
e-fans are from a company call Old Air Products and is a direct fit. Seems like I paid around $250 for it.
hooking up just depends on sticky tires. my street tires aren't and thus it can spin them (275/60-15 BFG's) from a 50mph roll. Put on the 315/60-15 MT ET Street radials and things are considerably different.
Kurt -
