Old 12-03-2012, 07:51 PM   #1
TobyArnot
Quit if it's not FUN!!!
TobyArnot's Avatar
Engine pulling Question
...Is it possible to pull the 350 engine & 350 turbo without removing the radiator core support? With a "cherry picker and and engine tilter"? Thinking about a little winter clean-up.
MY MOTTO:
Eat it all up, Wear it out,
Use the last few drops,
Spend all you've got,
Late in life, you'll think of the things you didn't do, not the things you did. - Get out and experience life !
Robbie Robinson a.k.a. TobyArnot (Toe Bee or not toe bee)
TobyArnot is offline   Reply With Quote
Old 12-03-2012, 08:32 PM   #2
hugger6933
Re: Engine pulling Question
yes it is very doable but it is helpful if you can get the bottom pulley off the crank[for a little added room] and just don't have too long of a chain on your tilter.
hugger6933 is offline   Reply With Quote
Old 12-03-2012, 08:54 PM   #3
68gmsee
Active Member
68gmsee's Avatar
Yes it can be done but do yourself a favor and take an extra few minute to remove the radiator -especially if it's in good shape. All it takes is one slip up and you damage it.
As an example, I once dropped a 1/2 inch wrench while working on the engine. It bounced of the fan, hit the radiator and immediately sprung a leak. I had to remove it and take it in. Lost time was 2 days and about $50 (that was back in the 80's).
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 12-03-2012, 10:22 PM   #4
TobyArnot
TobyArnot's Avatar
Good tips. I'll definitely pull the radiator, just didn't want to remove the core support.
Old 12-03-2012, 10:09 PM   #5
geezer#99
geezer#99's Avatar
And don't forget the most important part. Put a yoke in the tranny and tie it in place.
It's amazing how far a couple of quarts of atf will spread!
geezer#99 is online now   Reply With Quote
Old 12-03-2012, 10:18 PM   #6
DesertCat
DesertCat's Avatar
I debated that when I changed my 350/350 engine/trans and chose to pull the front clip as an assembly. Made the job sooooo much easier and only added maybe an hour to the job.
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131
DesertCat is offline   Reply With Quote
Old 12-03-2012, 10:32 PM   #7
VetteVet
Msgt USAF Ret
VetteVet's Avatar
I always pull the distributor as well, it gives me more tilt clearance and I don't have to worry about damaging the distributor.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 12-04-2012, 01:35 AM   #8
dukcaln
dukcaln's Avatar
didnt have to pull the radiator in my 72, but pulled the dizzy and removed the hood. No pulleys either and it was easy pezzy!
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP
SOLD 1972 chevy c10
dukcaln is offline   Reply With Quote
