12-03-2012, 11:52 PM | #1 |
aligning fender
i put new radiator core bushings in my 82 getting doors aligned and fenders before paint and passenger side was good but driver side has a big gap at the bottom of the fender anybody know the measurements of radiator core support bushings wonder if mine are wrong any tricks would be nice thanks....
Posted via Mobile Device |
12-04-2012, 07:54 AM | #2 |
Re: aligning fender
Need to know what is not oem as the fit is diff do to the staping. The way we did it when I worked auto body is start with the doors to cab then fenders too doors. If it is just to bushings holding it up then u need to get them tighter. As long as there not poly u will be ok
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph 1985 k30 "the ice cream truck from hell" no rust az truck 197-8??? c30 "ramp truck" 454 1978 monte carlo 350 350th with 2.73 gears. no rust. sc car |
12-04-2012, 08:38 AM | #3 |
Re: aligning fender
You can also take a big stick, like a 2x4, and pry rearward off the tire (pulling the rear of the fender wheel opening toward the door) while someone else tightens the anchor bolt at the bottom of the fender.
That's how it was done in the assembly plant, one per minute. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
12-04-2012, 05:19 PM | #4 |
Re: aligning fender
thanks for the advice the fenders and doors are factory i was wondering if i could align everything with the cradle off then go from there the bushings might to be to tall
12-04-2012, 07:26 PM | #5 | |
Re: aligning fender
1985 Chevrolet K10 Custom Deluxe---SOLD 1997 Ram 2500 5.9 Cummins 1985 Chevrolet Camaro Z28 1987 Chevrolet K10 Silverado "The Beast" build 1987 Silverado http://67-72chevytrucks.com/vboard/s...=1#post6150257 |
12-04-2012, 09:01 PM | #6 |
Re: aligning fender
Nope.
The stick was padded with lamb's wool and tape. Did about 3.5 million trucks that way (7 million if you count LH and RH side) and I don't recall any getting damaged. K
12-04-2012, 09:04 PM | #7 |
Re: aligning fender
Interesting, I just imagine that much pressure bending them, maybe I'm not giving the fenders enough credit for their strength.
12-04-2012, 09:46 PM | #8 |
Re: aligning fender
well its going to be either cutting the bushings or lowering the support brackets what would yall recommend
12-05-2012, 08:06 AM | #9 |
Re: aligning fender
What support brackets are you refering to?
K
12-05-2012, 08:35 AM | #10 |
Re: aligning fender
the radiator support brackets its only the driver side or i was thinking of triming the bushings to get the cradle to drop more
12-05-2012, 09:03 AM | #11 |
Re: aligning fender
Did you replace the cab bushings too? Maybe the cab is not sitting correctly if it has worn bushings.
12-05-2012, 09:38 AM | #12 |
Re: aligning fender
i measured the frame and the driver side is alittle high so im probally going to trim the bushing some how the frame got tweaked who knows its 30 yrs old
12-05-2012, 10:06 AM | #13 |
Re: aligning fender
Put a jack under the frame right behind the fender and with the lower bolt loose jack the truck up and watch the gap it should close up. While it's still up tighten the bolt and it should stay. There is acouple of bolts in the fenderwells that will also need to be loosened.
___________________ 78 ccsb dually 5.3 4l60e http://67-72chevytrucks.com/vboard/s...d.php?t=491551 |
