Old 12-04-2012, 12:03 AM   #1
rustyMUD
292 transmission options
After stopping to check out a local 'for sale' squarebody, I got to talking with the owner. We talked about the 73-87 trucks and he also showed me his current daily driver, which is an 84 four wheel drive short box. I asked him about the engine and was surprised when he said it had been a 305, but he swapped it out for a 292 from a 64 3/4 ton. As the owner of a 292 powered truck, I was intrigued.
We talked about chevy straight sixes and the specifics of the 292. The guy seemed very knowledgeable about the subject. However, one bit surprised me. He told me that 292 sixes only came equipped with manual transmissions. My face must have revealed my doubts, as he then told me to "think about it... when have you seen a 292 mated to an auto?" 292's are not very common around here, but the ones that I have seen were mated to sm465's. I attempted to justify this by suggesting that the 292 was the base engine in heavy duty 3/4 ton and one ton trucks. Thus when one picked the base engine, they picked the base transmission as well. But surely some picked the auto. It must have atleast been an option? He wouldn't have any of it, and insisted that the 292 was only mated to a manual trans.
I did some digging on the gm heritage center site and found that you could get a 292 with an automatic. However, in 1984 for example, this was only possible in a one ton. Any 292 powered 3/4 ton truck did not have an automatic transmission listed as an available option, only the sm465.
So with that, now I'm just curious to hear from others. Does someone own or know of a 73-87 truck that came factory equipped with a 292 and an automatic trans? I know that the 292 started in 63, but for my interests I'm looking at the 73-87 trucks.
FWIW my truck is a 1981 GMC K25 292/sm465/np208/14 bolt s.f.+ten bolt/4.10 gearing/ 8,600 lb GVWR.
rustyMUD is offline   Reply With Quote
Old 12-04-2012, 12:29 AM   #2
cory d
cory d's Avatar
Re: 292 transmission options
strange, the only 292's i have sen have had a sm465 behind them. i havent seen too many though. i havent seen tomany L6's around here, they all got swapped out for small blocks
cory d is offline   Reply With Quote
Old 09-06-2014, 07:32 PM   #3
RoughKuntry
RoughKuntry's Avatar
Guys, I have something for yall to ponder on, 250 bored out to 292 with The Bulldog SM465 transmission. Now my only problem is removing the SM465 to replace the Clutch Throw Out Bearing & Pilot Bearing... Anyone know of a better way to drop the transmission & tranfercase without having to remove the Cab Or Engine?
RoughKuntry
73 GMC 25 HUNDRED :Sold
79 GMC High Sierra 4x4 (Ma-Duece) :Sold
99 Chevrolet LS 4.8l/5 Speed Manual 4x4 :Selling
88 Chevrolet Burban 2500 4x4 :Buying
RoughKuntry is offline   Reply With Quote
