Old 12-04-2012, 03:20 AM   #1
62 Bowtie
62 Bowtie's Avatar
Porter Rack n Pinion Steering
Anyone have pics of there rack setup with the power steering pump and hoses? Also what pump and hoses did you use meaning part numbers or vehicle you asked for parts since most trucks didnt come with rack n pinion steering thanks, Tony
62 Bowtie is offline   Reply With Quote
Old 12-04-2012, 08:41 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Porter Rack n Pinion Steering
Porterbuilt uses a 79-93 mustang rack.
Your pump will greatly depend on the engine it's going on.
SBC?
BBC?
Long water pump?
Short water pump?
Contact Nate Porter.
He can get you the part number for the correct P/S hose kit for the rack.
Keith
Convert to disc brakes.
Old 12-04-2012, 08:45 AM   #3
lolife99
lolife99's Avatar
http://www.porterbuiltfabrication.co...and-Pinion-289
http://www.unisteer.com/power_steeri...cessories.html
Keith
Old 12-05-2012, 03:03 AM   #4
62 Bowtie
62 Bowtie's Avatar
thanks lolife yeah im useing the unisteer rack from PB SBC long water pump
Old 12-05-2012, 12:29 PM   #5
PBFAB.COM
PBFAB.COM's Avatar
We offer a hose kit with fittings for $105. It's a tight squeeze and the position of the pump and style will dictate the routing.
Give us a buzz and we can discuss a few things and help you get situated.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 12-06-2012, 03:16 AM   #6
62 Bowtie
62 Bowtie's Avatar
Thanks!
Old 01-10-2013, 06:15 PM   #7
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
can we use any GM power steering pump or do we need a certain pump?
Sick5 is offline   Reply With Quote
Old 01-10-2013, 07:14 PM   #8
PBFAB.COM
PBFAB.COM's Avatar
You can use any chevy pump. One thing to keep in mind is that the pressure rating of the chevy pump is higher than the pressure rating of the Ford rack. You may decide to use a pressure regulator to tune in the "feel".
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-10-2013, 07:14 PM   #9
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Not trying to high jack....
But what about guys running an LS series motor? Can we use the newer factory hoses if using the truck accessory brackets?
77' Chevy SB
Dropmembered Front and Rear
5.3/4l60e combo
JNJchev77 is offline   Reply With Quote
Old 01-10-2013, 07:19 PM   #10
PBFAB.COM
PBFAB.COM's Avatar
You can use the newer pump with our hose kit. You might be able to have new ends crimped on the factory hoses to save a little cash.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-10-2013, 07:30 PM   #11
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Were would I be able to find a pressure regulator
Old 01-10-2013, 07:35 PM   #12
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Thanks Nate! I will hit you up for the hose kit!
77' Chevy SB
5.3/4l60e combo
Old 01-11-2013, 11:58 AM   #13
PBFAB.COM
PBFAB.COM's Avatar
I would give Borgeson a call.
We have run several without reducing the pressure with good results and zero issues.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-11-2013, 12:18 PM   #14
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
So hoses... would I be able you use my same hoses.?
And thanks for answering our question.
Old 01-11-2013, 02:35 PM   #15
PBFAB.COM
PBFAB.COM's Avatar
You would have to have new ends put on the factory hoses to adapt to a 6AN male fitting. I think it would be easy to find a local hose and hydraulic shop that could crimp them on. We sell the fittings that screw into the rack housing and have the 6AN male for the hose connection.
Price it out for a local place... our hose kit with the proper fittings runs $105.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 02-25-2013, 09:28 PM   #16
BigShoe24
True Addiction
BigShoe24's Avatar
I ran the 14mm & 16mm with oring's and unfortunately the nipple does not fit down inside the female inset. Is is ok to run these conversion fitting without the oring portion and just us hyrdaulic loctite? Thanks,
RCC
BigShoe24 is offline   Reply With Quote
Old 02-25-2013, 10:16 PM   #17
PBFAB.COM
PBFAB.COM's Avatar
The problem is that the threads in the rack are not metric, but standard. We have the correct standard to an fittings in stock if you need them.
Nate
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 02-26-2013, 08:58 PM   #18
BigShoe24
True Addiction
BigShoe24's Avatar
Ahhh, well that explains it. I'll hopefully call the shop tomorrow to order a set. As always, thanks!
RCC
Old 05-13-2014, 09:42 PM   #19
BigShoe24
True Addiction
BigShoe24's Avatar
Nate,
Do you have a picture of the fitting? I'm having some issues with my pressure side.
RCC
Old 05-13-2014, 11:32 PM   #20
PBFAB.COM
PBFAB.COM's Avatar
Originally Posted by BigShoe24 View Post
Nate,
Shoot me an email tomorrow. I will send you a set. Nate@pbfab.com
Nate
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
