Old 12-04-2012, 03:26 AM   #1
BrutonLS1
BrutonLS1's Avatar
5.3 temp sensor conversion
Hey guys,
I've got a 5.3, it has 6.0 heads cast#317. I've bought 2 temp sensor adapters. I was trying to get my 1/8npt gauge to plug into the engine. The first adapter I had broke when I was tightening it (barely had any pressure on it) I then ordered another adapter from a DIFFERENT company, and the sender unit wouldn't go in all the way because there was an edge in the middle of the adapter that was blocking it, so I tried drilling out the adapter to fit the sensor, I drilled as far as I could without hitting the threads, and the sensor still wouldn't go in!!!
I decided to ditch the old goofy gauge with the long sensor and 1/8npt threads, and find a gauge that came with a short sensor and 1/8npt threads, that would fit right into my second adapter. I went to all 4 autoparts stores in town and found that NO ONE has a 1/8npt gauge!!! All the gauges I found had much bigger fittings. (I wish I remembered the sizes)
I would like to use the autometer gauge #4337 but do not know which adapter I need to make this work with the weird GM Temp sensor threads on the driver side cylinder head?? $70 and 2 frustrating weeks later, I'm asking for y'alls help. Thanks
-Bruton
1968 GMC long bed 5.7/700R4
--I'd rather push a Chevy, than drive a Ford.--
BrutonLS1 is offline   Reply With Quote
Old 12-04-2012, 04:33 AM   #2
Mr. 250r
Mr. 250r's Avatar
Re: 5.3 temp sensor conversion
Don't quote me on this but most people seem to leave the driver side head alone and then use the plug on the back of the passenger side head they will either....... take whatever temp sensor is matched to their original gauge set and then have a machine shop machine it down to a certain size since the old ones are bigger or do what you want and use an autometer setup but there has been some problems with that i think because i think the sensor its self wasn't well made i can't really remember, try a search it should bring a lot of results
EDIT this thread talks about both ways i believe http://67-72chevytrucks.com/vboard/s...d.php?t=488976 or this website has some stuff http://www.dakotadigital.com/index.c...cat/cat311.htm
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 12-04-2012, 09:58 AM   #3
rwade
rwade's Avatar
I used an adapter from speedway motors that I screwed in the passenger head near the firewall with a shorter Autometer temp sender. Worked well for me. I think summit racing sells the adapter too. When you call either place be specific in what your doing and that it's for an LS application, so you will get what you need.
rwade is offline   Reply With Quote
Old 12-04-2012, 04:40 PM   #4
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
I just tapped my head (sensor is only slightly larger then heads thread size) and screwed in the sensor....done.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 12-04-2012, 07:07 PM   #5
Indian113
Indian113's Avatar
X2 me too,I used the left head for gauge and the right head for ECM
Indian113 is offline   Reply With Quote
Old 12-04-2012, 10:39 PM   #6
68GMCCustom
mines arse backwards then.....
Kurt -
Old 12-04-2012, 11:00 PM   #7
Indian113
Indian113's Avatar
No big deal either side will work. I did what I had to as I had a mechanical sending unit for my temp gauge. It's a lot easier to add wire versus copper tubing
Old 12-05-2012, 02:26 PM   #8
68GMCCustom
was j/k....my harness had temp on drivers side...gauge on passenger side. As said...shouldn't matter tho!
Kurt -
Old 12-10-2012, 02:39 AM   #9
High ho silverado
High ho silverado's Avatar
If u get a sender for a 98 trans am it is a three prong sender, u mught have to get a plug too but u can take the wires out of ur old plug and put them in the right plug, its not very hard, anyways u can use the 3rd wire to run ur gauge, thats what I did. It worked out really good for me.
Dan G
Lift it, fat chicks cant jump!
83 Chevy shortbed 4x4: 6.0 ls powered
97 Chevy 3/4 ton ex cab 454: work horse
00 Chevy camaro: daily driver
83 Chevy 3/4 ton: dads old rig
High ho silverado is offline   Reply With Quote
Old 12-31-2012, 09:21 AM   #10
1970 C10 MJW
1970 C10 MJW's Avatar
subd
70 C10 working on a LSx swap
4.8L MS3 edelbrock pro flo intake, pacesetter long tubes, 4l60e 2500 stall hoping the tranny holds up lol
1970 C10 MJW is offline   Reply With Quote
Old 12-31-2012, 05:06 PM   #11
mooseknuckles
mooseknuckles's Avatar
my autometer guage uses the same sender as the one pictured. I ordered the autometer adapter, (forget the #) but IIRC it was 1/8 npt to 16mm?
mooseknuckles is offline   Reply With Quote
Old 12-31-2012, 05:09 PM   #12
mooseknuckles
http://www.autometer.com/cat_accesso...st.aspx?pid=11
its one of these....lol. I know I had to drill the center of the adapter out to get the sender to fit tho...
Old 02-08-2013, 11:19 AM   #13
JNJchev77
Registered Cruiser
JNJchev77's Avatar
This should be the correct fitting for the temp sender, if your using electronic gauges anyway...
http://www.autometer.com/cat_accesso...il.aspx?vid=61
77' Chevy SB
Dropmembered Front and Rear
5.3/4l60e combo
JNJchev77 is offline   Reply With Quote
Old 02-08-2013, 12:35 PM   #14
Jon01
Jon01's Avatar
Just a heads up, unless those heads have been cut or you have flat top pistons in your 5.3 it is going to be a real pooch.
317's have the largest chambers of all LSx heads and will drop your compression well below 9:1.
Advice, sell the 317's and get some 706/862/243/799's.
Jon01 is offline   Reply With Quote
Old 02-14-2013, 11:10 PM   #15
solidaxel
solidaxel's Avatar
Is the 98 Transam sender compatable with the gauge on a 78 Chevy truck and the ECM?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 02-15-2013, 03:19 AM   #16
ls1nova71
ls1nova71's Avatar
The 98 3 wire sensor will work for the PCM, but not sure it will work for a '78 gauge. My guess is it probably won't, or at least it probably won't be accurate.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
