Old 12-04-2012, 10:47 AM   #1
derrickmanx1
derrickmanx1's Avatar
To box or not to box?????
I came across a great deal on a powder coated frame. I want to know if it's worth boxing the frame to help the handling? It not an issue if I have to fix the powder coat I just want the truck to handle the best that it can. If there are other tricks i'm all ears.
NAME: TRAVIS TRUCK: BRUISER
71 C/10 SWB 3.5/5" drop 4.11 GEARS.
F.A.S.T. BBC 408 496hp/479ft/lb
JAKES 4L80E TCI TCU PTC 10.5" 2800 STALL
My build thread: http://67-72chevytrucks.com/vboard/s...30#post5779530
derrickmanx1 is offline   Reply With Quote
Old 12-04-2012, 01:52 PM   #2
69gmcc10
69gmcc10's Avatar
Re: To box or not to box?????
http://67-72chevytrucks.com/vboard/s...=419251&page=2
read post #31
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676
03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582
69gmcc10 is offline   Reply With Quote
Old 12-07-2012, 12:57 PM   #3
69gmcc10
69gmcc10's Avatar
what have you decided to do?
Old 12-07-2012, 02:52 PM   #4
derrickmanx1
I will box the back portion from the cab to the c-notch and putting a x-brace in that section with drive shaft loops. I'll box the front portion from the cab to the front sway bar. I will be using 1/8" steel. We will see though. When I get back home I'll start a build thread.
Old 12-07-2012, 04:27 PM   #5
69gmcc10
69gmcc10's Avatar
nice score!
Old 12-07-2012, 04:38 PM   #6
derrickmanx1
Yes it was. It is set up for leaf springs. I did get a rear trailing arm kit from CPP.
