Old 12-04-2012, 12:30 PM   #1
Mick Je
Mick Je's Avatar
Problem with my heater outlets
When I switch it from AC to heater the hot air still comes out of the AC outlets (on the dash) instead of down by your feet or the defroster outlets. It use to do this and it fix itself before.
343 NEVER FORGET 9-11
FIGHT ON!!! GO USC!!!
PROUD OWNER OF A 1970 1/2 TON
Mick Je is offline   Reply With Quote
Old 12-04-2012, 01:16 PM   #2
1972SUPERSB
1972SUPERSB's Avatar
Re: Problem with my heater outlets
Check under dash and make sure all cables are still connected to ac controller. Also check other end of cables that go to heater box under dash and under hood. May also check all vacuum hoses as well
Jeff
1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt
1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior
1972SUPERSB is offline   Reply With Quote
Old 12-04-2012, 03:10 PM   #3
Andy4639
Old member
Andy4639's Avatar
Talking Re: Problem with my heater outlets
The flapper cable is the one mounted on the floor vent housing. Make sure it's operating. The flapper will get old and start falling apart after years of operation also.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 12-04-2012, 03:58 PM   #4
landy
Same problem on my '72 Blazer. The flapper valve inside the heater box isn't moving correctly.
landy is offline   Reply With Quote
Old 12-04-2012, 04:03 PM   #5
boynton
boynton's Avatar
you might check to make sure your cable that controls the flapper door is adjusted correctly. also depending on the a/c system you installed you may be able to remove the section of plastic where the flapper door is and make sure there is nothing stuck in the door/in the way of the door completely closing. both are common problems.
boynton is offline   Reply With Quote
Old 12-05-2012, 08:23 PM   #6
Mick Je
Mick Je's Avatar
Thanks guys for the suggestions!!!! Got it working for the cold mornings in So Cal lately!!!!
