Old 12-04-2012, 01:12 PM   #1
oldman3
oldman3's Avatar
What year front suspension do I have
Keith,
Here are the pics I took of the front suspension in the 68 GMC short step side that we talked about in my PM.
Pic 1 is overall view of the pass. side front end.
Pic 2 is brake hose at front of crossmember
Pic 3 is close up of lower ball joint and spindle.
Pic 4 is close up of upper ball joint and spindle
Pic 5 is close up of upper A-arm cross shaft.
Pic 6 is close up of lower A-arm cross shaft.
Pic 7 is close up of upper a arm cross shaft near shock area.
Pic 8 is current tire and wheels on the truck (might help about the year)
Jim
oldman3 is offline   Reply With Quote
Old 12-04-2012, 01:17 PM   #2
oldman3
oldman3's Avatar
Re: What year front suspension do I have
Will only allow me to post 1 pic at a time so here goes
Pic 2 brake hose at front of crossmember.
Old 12-04-2012, 01:20 PM   #3
oldman3
oldman3's Avatar
Pic 3 close up of lower ball joint and spindle.
Old 12-04-2012, 01:24 PM   #4
oldman3
oldman3's Avatar
Pic 4 close up of upper ball joint and spindle
Old 12-04-2012, 01:29 PM   #5
oldman3
oldman3's Avatar
Will try two this time
Pic 5 close up of upper A arm cross shaft.
Pic 6 close up of lower A arm cross shaft.
Old 12-04-2012, 01:32 PM   #6
lolife99
67-72 parts collector,…
lolife99's Avatar
73-87
You can tell, because the a-arms have rubber bushings.
Keith
Convert to disc brakes.
Old 12-04-2012, 01:34 PM   #7
lolife99
lolife99's Avatar
It could be the 1" Light Duty rotor version or the 1-1/4" HD rotor version.
Keith
Old 12-04-2012, 01:35 PM   #8
oldman3
oldman3's Avatar
Pic 7 close up of upper A arm cross shaft near shock area.
Pic 8 current wheel on truck (might help about the year).
Old 12-04-2012, 01:39 PM   #9
oldman3
oldman3's Avatar
Thanks Keith,
It has the 1-1/4" rotors.
I really appreciate you helping me out with this. You can delete this thread if you want, or leave it, if it might help someone else.
Jim
